Question about Epson Stylus Photo 950 InkJet Printer
Replacing cartridges I wish to remove my non-epson cartridges and replace them with epson ones. They are not finished. How do I do this please?
  • joka44 Aug 14, 2008
    Thanks. Am not at home at the moment so will examine the printer closely when I return.
    I note what you say about non-epson cartridges but I am getting terrible colours especially redish face hues.
    Never had theses problems with epson cartridges.
    Have tried nozzle cleaning but perhaps soemthing else is wrong
  • 35 Answers
I believe if you just open the cover to get at the ink, and press the ink button - possibly several times, depending on your printer - the ink carrier should move to where you can remove the cartridge.  Then, you switch the cartridges.  And restart the printer.
I am not sure if this will work (it depends on your printer) and the way to check if it works is by checking the ink levels.  If they read the same as before you made the switch, it did not work and you need to use your printer's control panel to make the switch.  There should be a button under one of the tabs which reads "Change cartridges before empty" or some such language. That will give you step-by-step instructions.
Personally, I have seen no difference between the Epson and generic brand cartridges, so if I were you, I would run the non-epson cartridges dry in normal use and exchange them as you go along.
Posted on Aug 13, 2008
6ya staff
SOURCE:
Epson Stylus TX117. Why won't it print?
The user guide for this printer can be found here
Epson Stylus TX117 Manuals Documentation
see the section on troubleshooting - ink light continuously on n the second page. It instructs you to reseat the cartridges/check if they inserted fully and correctly. If the printer still does not work after doing this, remove the cartridges and re-insert them (on my printer there is procedure for replacing a partially used cartridge). Are your cartridges genuine Epson and within use by date ? Some printers can detect these things and fail to function. Although compatible non-OEM (ie non Epson) are usually ok sometimes they are not.
If none of the above apply, contact Epson support
Epson Support Home
My printer is out of warranty I use 'chat' (not needed support in fair while though), most problems quickly resolved.
7.July.2015
Jul 07, 2015 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus tx110 not function and their are leakage ink inside......
If you are using non-Epson nink cartridges you may need to get a replacement set of cartridges. Secondly, the ink sponge could be full. You can try a soft cloth to remove the excessive ink. Also, take a look here for the Epson utility to correct your error. Please leave positive feedback . http://www.ssclg.com/epsone.shtml
Sep 21, 2010 | Epson Stylus NX400 InkJet Printer
Black ink not printing
I suggest you replace the blank ink cartridge because it is possible the ink inside is finished.
Better still, if you can remove the black ink cartridge and check if the ink is still ok to print and you can equally try the black ink on a similar printer to see if it will print.
If it did not,then replace with a better one.
I wish you best of luck.
Apr 05, 2010 | Epson Stylus C62 InkJet Printer
I was using the printer and it was working fine and then I printed another sheet and the printer wouldn't just print, I had to press start and then it appeared to be printing, but the paper came out blank.
Hi, think the ink in the cartridge is finished, remove the cartridge to see if there is still ink in the cartridge, if non, please replace it with a new cartridge.
Jan 03, 2010 | Dell 926 All-In-One InkJet Printer
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Replace cartridge message with CIS that has been working fine.
Same problem with my R200. In reading solutions across net, said to use genuine Epson yellow and after finished, save chip from it to use on other non-genuine yellow. As soon as I put the genuine Epson yellow in, the problem went away.
Oct 26, 2008 | Epson Stylus Photo R340 InkJet Printer
Cannot recognize ink cartridges
If you are using non genuine Epson carts, then you need to change the carts to genuine ones (full set I'm affraid)
Once you have replaced the carts you should find the error goes away. The problem arises somehow from non genuine carts when one (or more) is inserted that has not been "reset" properly by the refiller. This causes a cascading error through the ink monitoring system and ends up with all your inks going empty one after the other. I've seen this on several models of Epson printer.
The alternative is that the printer has fault on the main board. try the carts first it's the cheapest option. If the nmachine is in warranty, get Epson out to it.
Jul 08, 2008 | Canon Pixma MP500 All-In-One InkJet...
Epson Stylus photo 2100
Highly possible that the "compatable" cartridges are not really compatable or that Epson has updated software or firmware to keep them from working. Try replacing with Epson cartridges or see if the non-OEM brand seller has a resetting device so the printer sees those cartridges as full.
Dec 06, 2007 | Epson Stylus Photo 2100 InkJet Printer
Open Questions:
See all Epson Stylus Photo 950 InkJet Printer Questions
Epson Stylus Photo 950 InkJet Printer Logo
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
