You shoud use Crisis Disk Recovery Creator to reload your BIOS. First search on net the BIOS file, it should be max. 1Mb syze and download it, it must be in .wph format. Download Crisis disk program, ver. 3 or 4 that supports USB memory cards, max. 4Gb. Copy the BIOS file in the crisis folder and rename it as BIOS.wph. Click on wincris.exe, select your USB device, it will create your Crisis disk on it. Your USB will be formated. Then, disconnect the battery from your laptop and the AC cable, insert USB card, press Fn+Esc and keep it pressed, connect the AC, wait 10 secs, power on the laptop, after 5-10 secs you can hear some beeps, then release Fn+Esc and wait 5 minutes. The laptop should restart completely functional.
Part Number:
Aspire5535 Aspire 5535
Feature
Description
Part Number
Varies by specifications
Processor / Speed
AMD
Turion™ X2 Ultra dual-core mobile technology
ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50
GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology,
or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1
MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD
HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor
QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W),
supporting AMD HyperTransport™ 3.0 technology.
Core Logic Chipset
AMD M780G Chipset.
System Bus Speed
667 MHz.
RAM / Max RAM
Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules.
Video Subsystem
ATI
Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of
dedicated system memory, up to 1792 MB of shared system memory),
supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR)
technology, Shader Model 4.0, Microsoft® DirectX® 10.0.
LCD Properties
Display 15.6"
HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer
CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via
Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time.
Hard Disk Drive
120/160/250/320 GB or larger hard disk drive.
Optical Drive
8X DVD-Super Multi double-layer.
Battery, Primary
48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use.
Sound Subsystem
Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone.
PCCard Support
1 ExpressCard™/54 slot.
Pointing Device
Touchpad
Peripheral Subsystem
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model)
Modem
56K ITU V.92 PPT approved, Wake-on-Ring ready
Ethernet
Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model)
Dimensions / Weight
15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack.
AC Power
100-240V AC AutoSensing Adapt
