Question about Toshiba 43HX70 43" Rear Projection Television
Blue halo on bottom 1/3 - Convergence issue with my 43HX70
My Toshiba 43HX70's blue is way off on the bottom 1/3 of the screen.
convergence appears to be out of wack. Blue has a halo effect on the bottom 1/3 of the screen.. any suggestions
  • Anonymous Oct 03, 2008
    Blue halo seperation of pictures, convergence cross of blue generator will not adjust up/down only side to side. suspect ic driver chip is no longer functioning properly.
    Who has these chips for this model, picture is of good quality for most part.
    Blue lagoon
    Scholar:
  • 167 Answers
HELLO SOUND LIKE YOU NEED TO CHANGE YOU IC CHIP'S ON THE CONVERGENCE BOARD.1!1 THERE WILL BE THREE OF THEM .!!! CHANGE ALL OF THEM AND THIS SHOULD FIX YOUR SET. "GOOD LUCK"
Posted on Nov 05, 2008
SOURCE:
Have a rear projection tv 55pp9352. Has green halos around objects on the screen. Checked convergence and all red and blue line up except that on the outside edges the convergence crosses are somewhat...
yes, you need remplace the liquid in the picture tube green and blue, and need remplace 2 parties stk-392-120 and resistences 6.8 ohms at 1/2 watts
Jan 05, 2010 | Televison & Video
Toshiba 43HX70 convergence problem
One or both of the STK convergence chips have probably failed.
I can give you guidance on this if you are confident to do the repair. I had the same problem with my Tosh 40WH08B and after replacing these chips it works like new.
May 21, 2009 | Toshiba Televison & Video
Convergence problem
sounds like you need to change the convergence chip to me. you can order a kit with instructions from www.tvrepairkits.com for most tv's.
If you plan on doing this you need a good soldering gun and a steady hand.
May 18, 2009 | Toshiba 43HX70 43" Rear Projection...
Yes its actually a very easy repair. You need two STK392-110 Convergence ICs and six 1.2 ohm 2watt resistors. You can get the replacement parts and instructions at the following link.
http://servicemanuals.vstore.ca/
Apr 27, 2009 | Toshiba 53H71 53 in. Rear Projection...
Convergence toshiba 50a62
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 20, 2008 | Apex Digital GB5108 51" Rear Projection...
Toshiba 50H81 projection television
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2008 | Toshiba 50H81 50" Rear Projection...
Convergence problem, blue ghosts
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
Blue Halo - convergence issue with 43Hx70
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2008 | Toshiba 43HX70 43" Rear Projection...
Toshiba 43HX70 convergence fix - now no video
I think the hardest to solve problems are those I installed!!
Where do we start==no lecture,but I never change a resistor
unless it has changed (in value!) Use a digital meter and check
the value of each resistor.Toshiba is a bit confusing as to values
of each resistor and location in relation to the IC's.Go over your own work first.Check micro fuses in power supply=F851,F852,
etc. Carefully resolder steel jumper wires at board edge,they feed
B+ to convergence amp circuit.Be sure to verify no shorts in pins
of IC's.(use your meter).........T
Oct 25, 2007 | Toshiba 43HX70 43" Rear Projection...
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Toshiba 43HX70 43" Rear Projection Television Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
