Question about Westinghouse LCM-22w2 Television
Westinghouse LCM22W2 shows a display then turns off after half a second
When I boot my computer up the dos looking screen with the processor info shows up then the screen goes black, green ON light still shows. When the windows loading screen is sent to the monitor it displays that for half a second then goes black, same thing happens when the windows desktop first shows up then goes black.
The green light stays on. If you turn it off then on the screen shows blue indicates what input is on then goes black. Pushing the input select button does nothing to change the black screen.
I'm not an electronics expert but all the components look fine and the soldering looks intact. I'm capable of basic unsolder-resolders.
Thanks for any help,
bryan
  • 3 more comments
  • Anonymous Oct 31, 2008
    If you fixed your prolem let me know what you did
  • zdravez Nov 08, 2008
    my lcm22w2 would not power up. the problem started with monitor blacking out sporadically. I had to power cycle to get it back working. Now it would not respond to anything. This is the 4th lcm22w2 unit to die on me like this for less than 1 year.
  • sal007 Jan 20, 2009
    I HAVE A WESTINGHOUSE (LCM-22W2) EVERY TIME I TURN IT ON AFTER 15 SECOND IT TURN BACK OFF.
    IF YOU HAVE ANY INFORMATION THAT CAN HELP ME PLEASE SEND ME A EMAIL AT [email protected]
    THANK-YOU.
  • Anonymous Mar 19, 2014
    I have a 46 LED westinghouse and out of no were it just showed a black screen. Can someone pls help me fine out what the problem is? There is no sound no white light just black
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Posted on Jan 23, 2009
SOURCE:
Desktop screen
try booting in safe mode and see if the screen displays properly.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the 1 inch black space then your video card might be going bad or you might have a virus infection. If the Borrowed monitor displays ok then your original monitor is bad.
May 29, 2012 | Dell Inspiron 530 Desktop Computer...
Have a westinghouse lcd monitor, 1080p that will not work with my older computer running windows 2000. have changed the resolution and HZ to specs. It will come up at computer boot, show the windows...
This is a windows issue which will not support display boot in safe mode by hitting f8 key after post after your in in safe mode change settings in control panel till it works,if it doesn't work windows does not like your monitor.
Jan 07, 2011 | Computers & Internet
Tell me aboout boot sequence in bios setup
The system BIOS is what starts the computer running when you turn it on. The following are the steps that a typical boot sequence involves. Of course this will vary by the manufacturer of your hardware, BIOS, etc., and especially by what peripherals you have in the PC. Here is what generally happens when you turn on your system power:
The internal power supply turns on and initializes. The power supply takes some time until it can generate reliable power for the rest of the computer, and having it turn on prematurely could potentially lead to damage. Therefore, the chipset will generate a reset signal to the processor (the same as if you held the reset button down for a while on your case) until it receives the Power Good signal from the power supply.
When the reset button is released, the processor will be ready to start executing. When the processor first starts up, it is suffering from amnesia; there is nothing at all in the memory to execute. Of course processor makers know this will happen, so they pre-program the processor to always look at the same place in the system BIOS ROM for the start of the BIOS boot program. This is normally location FFFF0h, right at the end of the system memory. They put it there so that the size of the ROM can be changed without creating compatibility problems. Since there are only 16 bytes left from there to the end of conventional memory, this location just contains a "jump" instruction telling the processor where to go to find the real BIOS startup program.
The BIOS performs the power-on self test (POST). If there are any fatal errors, the boot process stops. POST beep codes can be found in this area of the Troubleshooting Expert.
The BIOS looks for the video card. In particular, it looks for the video card's built in BIOS program and runs it. This BIOS is normally found at location C000h in memory. The system BIOS executes the video card BIOS, which initializes the video card. Most modern cards will display information on the screen about the video card. (This is why on a modern PC you usually see something on the screen about the video card before you see the messages from the system BIOS itself).
The BIOS then looks for other devices' ROMs to see if any of them have BIOSes. Normally, the IDE/ATA hard disk BIOS will be found at C8000h and executed. If any other device BIOSes are found, they are executed as well.
The BIOS displays its startup screen.
The BIOS does more tests on the system, including the memory count-up test which you see on the screen. The BIOS will generally display a text error message on the screen if it encounters an error at this point; these error messages and their explanations can be found in this part of the Troubleshooting Expert.
The BIOS performs a "system inventory" of sorts, doing more tests to determine what sort of hardware is in the system. Modern BIOSes have many automatic settings and will determine memory timing (for example) based on what kind of memory it finds. Many BIOSes can also dynamically set hard drive parameters and access modes, and will determine these at roughly this time. Some will display a message on the screen for each drive they detect and configure this way. The BIOS will also now search for and label logical devices (COM and LPT ports).
If the BIOS supports the Plug and Play standard, it will detect and configure Plug and Play devices at this time and display a message on the screen for each one it finds. See here for more details on how PnP detects devices and assigns resources.
The BIOS will display a summary screen about your system's configuration. Checking this page of data can be helpful in diagnosing setup problems, although it can be hard to see because sometimes it flashes on the screen very quickly before scrolling off the top.
The BIOS begins the search for a drive to boot from. Most modern BIOSes contain a setting that controls if the system should first try to boot from the floppy disk (A:) or first try the hard disk (C:). Some BIOSes will even let you boot from your CD-ROM drive or other devices, depending on the boot sequence BIOS setting.
Having identified its target boot drive, the BIOS looks for boot information to start the operating system boot process. If it is searching a hard disk, it looks for a master boot record at cylinder 0, head 0, sector 1 (the first sector on the disk); if it is searching a floppy disk, it looks at the same address on the floppy disk for a volume boot sector.
If it finds what it is looking for, the BIOS starts the process of booting the operating system, using the information in the boot sector. At this point, the code in the boot sector takes over from the BIOS. The DOS boot process is described in detail here. If the first device that the system tries (floppy, hard disk, etc.) is not found, the BIOS will then try the next device in the boot sequence, and continue until it finds a bootable device.
If no boot device at all can be found, the system will normally display an error message and then freeze up the system. What the error message is depends entirely on the BIOS, and can be anything from the rather clear "No boot device available" to the very cryptic "NO ROM BASIC - SYSTEM HALTED". This will also happen if you have a bootable hard disk partition but forget to set it active.
Dec 15, 2010 | HP Computers & Internet
M1400 Tablet-PC doesn't boot anymore. Hangs up while loading Windows. Shows blue screen with message "Windows has detected...." for half a second and restarts itself.
get a hirens boot disk. that will fix ya right up. boot from the disk. choose either option boot windows xp mini or from boot disk. do not choose the option boot from hard drive or you will get no-where.
Jul 15, 2009 | Motion Computing M1400 Cent PM 733...
Pc is restarting but doesn't show the log on screen
It sounds like your Windows Installation is corrupt. If there isn't anything you need on the drive, I would get a Windows XP CD (Look on the side of your case for a Windows Key, Get that version of the CD) Then I'd use that windows XP CD to wipe the drive and Re-install windows. If there is Data on the drive you need, You will need to invest in either a second HD, or You need to Install Windows on a Second HD and boot from that if you already have a second HD.
Jun 21, 2009 | Dell 2.8 GHz Second Processor for...
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
I cant identify the prolem
It looks like you may have a boot sector virus. A boot sector virus is one that infects the first sector, i.e. the boot sector, of a floppy disk or hard drive. Boot sector viruses can also infect the MBR. All disks and hard drives are divided into small sectors. The first sector is called the boot sector and contains the Master Boot Record (MBR). The MBR contains the information concerning the location of partitions on the drive and reading of the bootable operating system partition.
When disinfecting a boot sector virus, the system should always be booted from a known clean system disk. On a DOS-based PC, a bootable system disk can be created on a clean system running the exact same version of DOS as the infected PC. From a DOS prompt, type:
    SYS C:\ A:\
and press enter. This will copy the system files from the local hard drive (C:\) to the floppy drive (A:\).
If the disk has not been formatted, the use of FORMAT /S will format the disk and transfer the necessary system files. On Windows 3.1x systems, the disk should be created as described above for DOS-based PC's. On Windows 95/98/NT systems, click Start | Settings | Control Panel | Add/Remove Programs and choose the Startup Disk tab. Then click on "Create Disk". Windows 2000 users should insert the Windows 2000 CD-ROM into the CD-ROM drive, click Start | Run and type the name of the drive followed by bootdisk\makeboot a: and then click OK. For example:
    d:\bootdisk\makeboot a:
Follow the screen prompts to finish creating the bootable system disk. In all cases, after the creation of the bootable system disk, the disk should be write protected to avoid infection.
Once the OS loads, run your anti-virus software and it should clean the virus.
Should this not help, I'm afraid the only other alternative would be to reformat the HDD and reinstall XP again from a bootable disc.
Hope that helps..
May 07, 2008 | Computers & Internet
Screen won't display,
Did you plug in the 4-pn 12v_ATX connector loacated on the board near the CPU? Ya got to have this or your the CPU will stop you in your tracks.
Feb 23, 2008 | AMD Athlon 64 x2 3800 3800+, 2 GHz...
Westinghouse LCM22w2 Monitor
I'll buy it from you. I just need a non-cracked LCD from this monitor. It doesn't even need to turn on. You can e-mail me at [email protected]
Jan 30, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Westinghouse LCM-22w2 Television Logo
803 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
