Question about HP LaserJet 1300 Printer
Ink my photographs print with lines on the picture
    Master:
    Sergeant:
  • 398 Answers
1st replace your toner cartridge, and try it.
Posted on Aug 13, 2008
There is a 3 cm line through my page from top to bottom that is blank when printing
Hi it is usually the fuser that causes this problem You will have to replace it.
Sep 27, 2016 | CISinks Continuous Ink Supply System] for...
Ive just bought this printer from currys & im trying to print a picture from my memory sd card & the picture is coming out all smudged? could it be because im not using photographic paper?
You should be able to select the paper type you use before starting the print. The printer should optimise the print to match the paper you have specified. If the paper is not for photos, it shouldn't matter too much unless the ink is taking too long to dry. It is more likely that your print heads are skimming the paper or something is brushing the image while the ink is still wet.
Apr 13, 2016 | Office Equipment & Supplies
Hi there I have the original canon cartridges in the printer and they all have lots of ink in them, but suddenly when printing the 'black' parts of a photograph looks purple. But when I print text in...
When you are printing a photograph, the back is resultant of combination of RGB but when you print a latter of document it usages only the black ink. So since the black is properly printed when it's combining RGB that means any of the color is low on ink. Replacing the color cartridge will solve the problem for you.
Mar 15, 2011 | Canon Pixma iP4500 InkJet Printer
Streaky lines through photographs when printing
remove the ink cartrages and clean the connections and print heads with rubbing alcohol on a qtip. this will be messy. let dry for a few minutes and reinstall the cartridges. also streaks can be caused by low ink.
Mar 07, 2011 | Brother MFC 210C All-In-One InkJet Printer
Black lines in pictures printed from Artisan 800
I have the same issue, It seems 1 line of pixels is overlapping with the next set of pixels and makes a dark line horizontally.
Apr 23, 2010 | Epson Artisan 800 All-In-One InkJet...
Canon MP600 printer. Black Ink cartridge PGBK5 is
You need both. One is pigment and the other is dye. One is used for photographs and the other for non-photographs - but it's the printer that decides which one to use.
All Canon printers (to my knowledge) will stop working if any one ink cartridge is empty. This is to prevent damage to the print nozzles. The ink itself is the cooling medium for the hot nozzles.
Nov 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Lines on photographs,
try cleaning your printer heads in your printer settings in the control panel. might have to do it a few times and it will use your ink.
Oct 01, 2008 | HP Officejet 7210 All-In-One InkJet...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
HP LaserJet 1300 Printer Logo
15 people viewed this question
Ben Johnson
