Video problem Lost video on Dell M50 notebook. Shows up extremely dim on LCD, and no video with external monitor. Replaced video card and motherboard--no change. I can't see that it would be the LCD screen, since external video doesn't work at all either. Any ideas? Thanks!
  • billrenn Aug 28, 2008
    Thanks Pyrhyc, I tried your suggestion (unhooked the LCD display and plugged into monitor) with all combinations of old and new video cards & motherboards.
    The results are the same--the monitor displays clearly during POST and initial Windows XP login splash screen, and the Windows welcome sound, and then the screen turns black.
    There is a bluish tint to everything, with both video cards, for some reason. I can get into setup menus and it'll stay on indefinitely. Still stumped! Any further thoughts?
    Thanks very much for your help.
  • chasrn Dec 12, 2008
    my laptop starts up noise and runs flickers and then the screen goes black
    then try again and get vertical lines
    Genius:
  • 2,028 Answers
Generally this type of problem is the video card, however, it's extremely rare, but sometimes a screen malfunction will override the video out causing the appearance of a bad card. To check this, disconnect the screen, and try the external monitor. If the external works properly, then it's the screen.
Posted on Aug 13, 2008
  • Ryan Rogers
    Ryan Rogers Aug 28, 2008
    Wow, this is a tough one without having it in front of me. The only other thing I can suggest to check would be the screen inverter. Possibly the inverter is bad or shorting and cancelling out the video card. Change out the inverter and see what happens. If this doesn't work, then I can only suggest taking it to a shop for diagnosis. Stay away from the Geek Squad, those idiots won't be able to fix it, their mainly software oriented, and although they talk a good game (baffle with BS), don't know jack when it comes to component hardware issues, unless it's plug and play, and then it's still 50/50.
  • Ryan Rogers
    One more thing, have you tried a different cable/ribbon on the screen? It's just a thought, it's kind of silly to get stumped over aa cable, but it happens. It seems that the cable is one of the most overlooked items in repairing screen problems. I'm guilty of overlooking it.
Dell Inspiron MINI 1012 Laptop Screen 10.1 LED flickers
soldbyajt,
It sounds as though the video card has gone bad in your system. There are a couple of things to try to eliminate the lcd.
If the LCD on the system shows no display or has other problems, here are some basic steps to take:
  1. If the LCD is not displaying any video, connect an external monitor to eliminate a no-POST problem. A good image on the external monitor eliminates a video card problem or a POST problem.
  2. Connect an external monitor when possible for all LCD-related problems to help eliminate a possible software or video card problem.
  3. If the LCD has lines on the screen, check the system during POST as well as system setup to determine if the lines are present in all modes of operation.
    If you cannot get any video by connecting an external monitor then your motherboard will need to be replaced. The reason for the motherboard replacement is because your video card is soldered onto the motherboard.
    Thank You,
    Dell-Jesse L
    Dell Social Media and Communities
Jan 11, 2013 | Dell Inspiron Mini 1012 Netbook
I have a 1cm verticle stripe on my Dell Studio 1737 ?
Your lcd screen is going bad. You can verify this by plugging an external monitor to your laptop. if the external monitor shows without the vertical stripe it means the video card is good but your old screen is bad. If the external monitor shows the stripe then it means the video card is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 02, 2012 | Dell Studio 1737 (Studio 1737-RubyR) PC...
My dell inspiron 6400 won't start, red light then green light flashes ansd nothing happens, try to take out the battery and putting it back, no results, help
The following troubleshooting guidelines are basic troubleshooting steps. Battery Charging It is recommended to charge the battery while the system is off for faster charge times. Users may notice longer charge times when the system is powered on and running graphics extensive applications.
No POST If the system does not perform a Power On Self Test, there are various things to look for:
  1. Check to ensure that the system has a power light.
  2. If the system has no power light, ensure that it is plugged into AC power. Remove the battery.
  3. If the system has power but is not performing a POST, check to see if the keyboard status lights flash to indicate a successful POST, but no video, or that the keyboard status lights are lit in a sequence indicating a system problem.
  1. With the power off and the system unplugged, remove all CRUs from the system and reconnect that AC adapter to the system and try again.
  2. Run the On Board Diagnostics (OBD).
Video If the LCD on the system shows no display, or has other LCD problems, there are some basic steps to take:
  1. If the LCD is not displaying video or the video is garbled, run the BIST Test.
  2. If the LCD is not displaying any video, connect an external monitor to eliminate a no POST problem. A good image on the external monitor eliminates a video card problem or a POST problem.
  3. Connect an external monitor when possible for all LCD related problems, to help eliminate a software possibility or video card problem.
  4. If the LCD has extremely dim video, attempt to adjust the brightness or connect an AC adapter to eliminate a power management conservation setting set in the BIOS.
  5. If the LCD has lines on the screen, check the system during POST as well as system setup to verify if the lines are present in all modes of operation. Run the BIST Utility.
  6. If the LCD has color problems, run the BIST Utility.
  7. Run the On Board Diagnostics (OBD).
Jul 19, 2011 | Dell Inspiron 6400 Notebook
Can't get my Dell Precision M50 Laptop video to fill the screen at 1024 768 resolution. Video will only fill the screen when I set resolution to 1600 1200. Is there something wrong with my video card?
1024x768 is a native wide-screen resolution. more than likely your video card is fine and your notebook monitor does not support that format without shrinking the top and bottom which defeats the purpose of filling the whole screen. plug the kappy into an external widescreen monitor or TV and it will work at 1024x768.
Regards
Jun 06, 2010 | Dell Precision M50 Notebook
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
LCD dim.
If you have replaced the screen and the inverter, about the only thing left is the flexible cable from the monitor to the video card. I take it that the Fn+F8 makes no difference?
May 23, 2009 | Dell Latitude L400 Notebook
I turned the my toshiba M50 last night. the next morning i was trying to turn it on, but it was just a black screen. i can hear the sound that it actually turned on but the screen is just black and no any...
If you see a dim image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 07, 2009 | Toshiba Satellite M50 Notebook
Dell inspiron 4150 video dim
The empty slot is for a mini-PC card, usually a wireless network card. The 2 wires are actually the antenna wires that connect to the wireless card. The dim LCD may be a problem with the LCD panel display, video controller or motherboard. Try connecting the laptop to an external monitor by connecting to the Video Connector located on the back of the laptop. If the display on the external monitor appears to be normal, then your LCD display panel on the laptop has a problem. If the display on the external monitor is dim then you probably have a bad video controller card or motherboard.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 4150 Notebook
Computers & Internet Logo
314 people viewed this question
David Payne
David Payne
