Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Insulation(?) coming out of bottom of freezer door
On the underside of my freezer door is a black disk about the size of a quarter. It sticks out a little bit. It has torn on one side and a styrofoam looking substance is sticking out and will flake off if poked. Sears says it's nothing to worry about, but it looks to me like whatever is inside the freezer door is trying to get out.
Is this the insulation coming out? Is it toxic and will it get on my food and cause me to be rushed to the hospital to have my stomach pumped?
Any advice would be appreciated. Thanks! l
  • 706 Answers
That 'black disk' was probably a plug. Many manufacturers have extra features that if aren't used, get wired into the appliance anyway and have a plug placed over the opening. What you were seeing is foam insulation and as long as you don't consume it.. you should be OK.. A small piece of duct tape over the opening might make you feel better about it... You may have to thaw the freezer out and clean the area a bit for the tape to adhere properly... Hope that helps !
Posted on Aug 13, 2008
Door on Kenmore Dishwasher dropping out pieces of black insulation on the floor and into the dishwasher basin. What is it? Can the insulation be replaced or is it new dishwasher time?
If it seems noisier, these black pieces are pitch (a hard tar-like substance) that's coated on dishwasher doors to make them quieter. Just to be safe, though, it might be a good idea to show them to somebody in an electrical shop.
Jan 23, 2015 | Kenmore 24 in. Elite Built-In Dishwasher...
Ice in the bottom of the freezer
Check the door gasket for a leak. Air entering past the gasket will form ice.
Sep 23, 2014 | LG LRBN22514ST Bottom Freezer Refrigerator
Freezer drips water into fridge
There is drain tube that empies into a small pan at the bottom of the fridge. Follow it up to see where it connect and make sure its in place. If your freezer is constantly defrosting itself and wont keep your food frozen you might want to replace the bi-metal. The "bi-metal" is a small coin sized thermostat of sorts. Its easy to replace if you can splice wires together and wrap in black tape.
Remove the back panel inside the freezer and look for a quarter sizes disc with two wires coming from it. Cut the wires leaving enough to splice the new bi-metal into place and wrap each wire with black tape. This will fix 99% of the problems with freezers always in defrost mode and leaking water into a fridge.
Jul 18, 2011 | Whirlpool Refrigerators
I just dropped a frozen turkey to the bottom of my chest freezer and it made a puncture in the metalic lining. The size is about the size of a quarter or less, and I can see the insulation under...
Good day,
Your idea was a good one, and it should not be neglected. The area your going to tape should be warm and dry. Best long term repair, would be to cut a small piece of aluminum, and epoxy it in place. The machine will need to be warm long enough for the epoxy to set, however, it should be a permanent repair.
Nov 15, 2010 | GE 7 cu. ft. Chest Freezer FCM7DR
Icemaker works fine but no water at door. Have water at bottom of door at quick connect but not at dispenser.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . There is also , a dispenser heater , pt . # WR49X10173 , which comes with instructions , to keep this grom happening again .
Nov 26, 2009 | Hotpoint HSS25GFP Side by Side...
The cold water dispencer freezes in my amana bottom freezer refrigerator
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
Aug 26, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Bubbling sound coming from the bottom of my freezer
There is a vacuum build up in the freezer compartment when you close the door. This can make the door difficult to open. You can overcome this by sticking a small lollipop stick to the bottom part of the door gasket. This will act as a vacuum breaker.
Mar 06, 2009 | Whirlpool Upright Freezer EV161NZRQ
Need to remove panel in front of evaporator fan
there should be screws in the top and bottom of the freezer compartmant. after emovinghte screws it should tip out alolowin gyou access to the screwsfrom behind the panel
Nov 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
How do we access the waterline inside the freezer door?
The waterline comes out the lower door hinge. Unhook from coupler at bottom. Now go to the despencer and carefully take the cover off some have screws under drip plate or clipped which a flathead screw driver works nicely dont scratch finish. With proper water line usualy 1/8 size about 5foot long snake it down to the bottom hinge and rehook up. In some case if the tube gets kinked you may have to remove door to do it it. Usually pretty easy.
Jan 20, 2008 | Amana SXD524VW Side by Side Refrigerator
Water dripping from underside of chest freezer
First make sure the door seals are sealing correctly and not letting the air in to the compartment because this is the only source of water.
Check that there is no ice buid-up around the seals.
Oct 11, 2007 | Whirlpool ET1FTKXK Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
74 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
