Question about HP Office Equipment & Supplies
Does HP2575 read SDHC SD cards - HP Office Equipment & Supplies
  • freeradicalm Mar 14, 2009
    my 4 gig sh "hc" card is not recognized by my hp-7960 hooked up to my mac. It works in a windows machine, though
  • HP Master
  • 2,794 Answers
HP2575 doesn't read SDHC cards. You can only read SDHC cards in devices approved for SDHC use.
Posted on Aug 13, 2008
My lg does not read 2gb sd card.it tell me to insert a new one.Bt it can read 128 mb sd card
Your 2 Gb is not just an SD card, it is a SDHC card. The first 2Gb SD cards, still were SD, but 2Gb was the limit for the FAT 16 and 32 format and for the normal SD cards. The same happened with the hard disks. They developed the SDHC card, and made the new hardware downward compatible with the old SD cards. So in a new camera, you can insert SDXC, SDHC, SD and even MMC cards. But the cameras, card readers and phones, who were made for SD, can't use the SDHC or SDXC cards.
SDHC can work with memories up to 32 Gb and from that on, it is SDXC.
There still should be some 2Gb SD cards around, but not sure you still can fine one. The producers of memory cards now only make SDHC cards and up. Perhaps you only can get some 1Gb cards as SD card, but perhaps nobody will ever make these cards anymore.
I mannaged to buy a 4 GB SD card a few years ago, but that was the last I ever saw in the capacity. 25264488-uil2tdgcy05knvgzh4oup5lj-2-0.png
Nov 01, 2014 | Cameras
My Lumix DMC ZS7 reads "insert sd card again" when I have a full sd card inserted. The sd card is "verbatim sdhc 4gb" any idea? Thanks in advance
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
Jan 18, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
Camera reads communication error when trying to upload photos what might be the prob
I BELIEVE THE REASON IS THE TYPE OF SD CARD.
THERE ARE SD AND SDHC. IF YOU ARE USING SDHC.
I BET THE ONE CARD THAT DOESNT READ IS AN HC. THIS IS ALSO TRUE WITH OLDER CARD READERS. I HAVE AN OLDER AND NEWER CARD READER.
I JUST HAPPENED TO PUT AN OLDER SD CARD IN MY NEW POWERSHOT SD1300 AND IT READS FINE, ALL NEW CARDS SDHC WONT READ.
I BELIEVE SD IS UP TO 2GIGS AND SDHC IS 4GIGS AND HIGHER.
Aug 24, 2010 | Canon PowerShot SX120 IS Digital Camera
I cant seem to access MY SD Memory Card from my New Camera through the SD Card slot on the Front panel of My Aspire M1201 - The Green LED is on but no pop up and i cant find the correct the section to...
Newer cameras may have SDHC cards - these have a high capacity. Older computers can't read the newer SDHC cards - they can only read the old SD Cards. The SD card and SDHC cards look exactly the same. The SDHC card will probably say "SDHC" on it somewhere. Fortunately you can buy a USB SDHC card reader for a computer for around £2 on amazon. I would buy one of those. You could search the internet for "usb sdhc card reader".
Jun 13, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
What is the maximum SD size that will work with the DSC-4500Z camera?
The manufacturer of your camera specifies SD card compatibility without providing a specific number. This is not uncommon however, as the maximum size for SD cards is 2 GB. Cards that have a larger capacity than 2 GB in the "SD" format are "SDHC". Read the label of these cards (that have a larger capacity than 2 GB) that *look* identical to SD cards, and you'll see that they are in fact SDHC types. The SDHC card can have a capacity of up to 32 GB. A device that is compatible with the SDHC specification should be able to read any SDHC card *and* any SD card as well; because the standard requires "backward compatibility" to the older SD standard. A device that accepts SD cards should be able to read any SD card, *but* if an SDHC card be introduced to it, it may provide unreliable results (from being able to access only 2 GB of the capacity or not recognizing the card at all). Make sure your pictures are safe and don't get lost; use only SD cards in this camera.
I hope this helps!
Jun 08, 2010 | Apex Digital Digitrex DSC-4500Z Digital...
I have a fuji a204 with xd card.Iwant to buy A FUJI s1500 with sd/sdhc card will both work with sd/sdhc software download
In general, photo transfer software doesn't care what kind of card you have, as long as the card reader can read the card. One thing to check for if you want to use SDHC cards: make sure the card reader can read SDHC cards as well as SD cards.
Feb 26, 2010 | Fujitsu Cameras
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
Dec 14, 2009 | Audio Players & Recorders
I have a 4gb sandisk micro sdhc with adapter and the computer freezes when i have it in the sd drive.I have a hp pavilion a1 a1203w. Is there anything i can do?? Please Help
I had a similar problem not long ago. The SD and SDHC standards are different. SD only goes up to 2GB, and SDHC (high capacity) goes higher than 2GB. THe problem is that SD card readers aren't capable of reading SDHC cards, even though the card will physically fit into the card reader slot. When you insert an SDHC card into an SD card reader, the reader attempts to read the format, and locks up the OS while trying. You'll need to get an SDHC card reader and use it separately like through a USB port or something.
May 13, 2009 | Computers & Internet
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
322 people viewed this question
Seeker5211
Seeker5211
