Question about Jenn-Air Refrigerators
Side by side Jenn Air model # JCB2388AR fridge/freezer
Jenn-air side by side neither keeping things cold in refridge or frozen in freezer
  • Anonymous Apr 01, 2014
    temperature may have dropped
    Master:
  • 521 Answers
Thermostat problemfor sure if not then
not probably it could be compressor if it is the problem it wiil be costly.
Posted on Aug 13, 2008
  • 3,037 Answers
How cold is the freezer, stick a thermometer in and figure it out. Is the fan in the freezer running? Check for ice build up on the coils. Let me know what you find after doing the above
    Sergeant:
    Champion:
  • 248 Answers
Try to unplug your appliance to defrost it then clean it after this try it plug it again to see if there is change...if sitll not working...first check thermostat if working. check your compressor and fan make sure it clean and working if not you need replacement for this parts.
  • 13,433 Answers
Have a look over here
http://www.repairclinic.com/0088_4_1.asp#Level1_2
also more common problems and solutions at
repair parts also available at the same website
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
I have a Jenn-Air JCD2295KES side-by-side - freezer fine but the fridge too cold
The thermostat is not registering temperature correctly. If you have thermistors they should be replaced
Feb 27, 2014 | Jenn-Air JCD2295KES Stainless Steel
I have a Jenn-Aire side-by-side refrigerator Model #JCB2280HES, Serial #10024253EP. The warranty expired in February 2010. The food in the bottom half of both the freezer and refrigerator is frozen and...
Hi!!
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Good Luck!!
Jul 29, 2010 | Jenn-Air JCB2280HES Side by Side...
Jenn Air side by side refrigerator Model JCD2389GES is still making ice, food is still frozen on ice making side, but the refrigerator side is not cold, milk is souring rapidly and vegetables are turning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Dec 09, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
I have a jenn air side by side. the freezer is
This is usually a sign of a defrost problem. I will need you model number to help you better. Sea Breeze
Jun 26, 2009 | Jenn-Air Refrigerators
Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Nov 24, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Sep 26, 2008 | Jenn-Air JCD2290HES Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
102 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
