Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
New Battery Charge?
I've read over some of the other solutions, but I want to make sure I undersatnd this. I bought a new battery for my Creative Nomad Jukebox Xtra, and plugged it into the wall charger. If I turn it on, instead of the little battery icon there is a power cord.
I've tried leaving it on to try to charge it, turned it off, and it isn't charging. Do I *have* to use the USB cable to "jump start" the charging process for the battery? After that, can I then use the wall charger to finish the charging process
  • channingg Aug 13, 2008
    AHA!!! That was actually it ... the battery polarity *was* correct, but there is a small plastic strip to help pull the battery out of the casing, and I had left that underneath the new battery. I think that was enough to prevent a connection.
    I doublechecked by putting the old battery back in; then, the new battery. It's now charging!
  • channingg Aug 15, 2008
    One little note ... it didn't work again when I turned it on, but what I found is that the battery was just a little loose, so I cut a very small strip of post-it notes to fit inside the gap which pushed it tight against the connections to the unit. Works perfectly.
    Problem Solver:
  • 5 Answers
This means your unit does not see the battery and is running on AC power only. You need to check and make sure that your battery polarity is correct making sure that positive goes to positive, and negative to negative. If you can attach some photos, that might help also.
Posted on Aug 13, 2008
  • raresolid Aug 15, 2008
    Glade you got it working, have fun with the player. :) I have one myself, I like them.
Chevy van g20 year 1994 the battery dies has new battery and new alternator but each morning its dead need to charge the battery need help have any ideas and please talk problem please
Does the battery light work when you switch the ignition on? This provides a live feed to the alternator via the ignition bulb, the rotor needs a live feed to start the charge process, if the bulb has blown it won't charge (thin wire connected to the IND on the alternator). To check for a power drain, disconnect the negative battery lead put a AMP meter in series, (DON'T TRY TO START, YOU WILL BLOW THE METER). If you get a reading above 0.05amps (clock) you have a drain, pull the fuses one at a time and watch for a drop in the meter reading. Hope this helps.
Jan 24, 2014 | 1994 Chevrolet G20
My Jukebox will not take the charge
IF you remove the battery does it function the same way? that would indicate that the battery is not connected into the circuit.. loose connection or broken wire.
Aug 26, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Packard bell netbook nav50 battery stopped charging properly. bought a new charger and battery and it still wont charge it up.
LOL, I didn't know Packard Bell was still making computers. I would think they sold you a bad battery. I've purchased new batteries before that would not charge.
Apr 04, 2012 | Computers & Internet
MTG 900 SAYING "CHARGE" AND I'VE BEEN PUTTING
I am assuming you are reading the battery charge correctly. If so you need a new rechargable battery. Special battery so it is a little expensive. Make sure the person knows it is a "rechargable battery" you want. A regular battery will not work properly or recharge.
Nov 02, 2011 | Casio Atomic-Solar MTG900 Watch
Vreative zen will not charge
I used to work in a IC design department where we disigned IC's for creative. It is a problemn of the lition ion charging circuit. When voltage drops under 0.9 volt (if I remember clearly) It will not detect
the battery anymore and wil not charge..
So, solution:
1 try to charge the battery manually for a short time, disassemble the vision and connect the battery to up to 3.7 volts. For a while, later your device can charge it further, by itself
Jun 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
Hello ,i've a problem with creative zen vision:m version 1.40.02
Make sure it is connected to a computer with a working USB 2.0 hub - if it doesn't charge that way, then the hardware is damaged, and the mp3 player will need to be replaced - cut and dry - no ifs, ands, or buts
Jun 22, 2008 | Creative Labs ZEN Vision:M Digital Media...
Battery won't charge
is it under warranty? if not send it here
http://www.zenrepair.com/Zen/index.jsp
Feb 14, 2008 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
90 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
