Question about Maytag 24 in. MDB6100A Built-in Dishwasher
Mdb6601awq control lights flash at times, cant always start dishwasher. rinse only with 9 min. comes on.
5 Suggested Answers
  • 18 Answers
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Posted on Feb 04, 2007
  • 868 Answers
SOURCE: Can I buy a stainless steel door for my 2 yr old Maytag Bisque Dishwasher MDB6601AWQ?
Yes you can.
Posted on May 20, 2008
  • 1998 Answers
SOURCE: why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Posted on Nov 17, 2011
Testimonial: "Rick Ead's rapid response led to a solution within an hour. His suggestions were correct and after figuring out the button combination for out particular machine we were up and running."
  • 14405 Answers
SOURCE: Dishwasher won't start
Unplug,then plug up,may reset.
Posted on Nov 23, 2012
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
I have the Whirlpool Quiet Partner 1 the wash cycle starts and about 20 Min.'s into it the clean light starts flashing or the the start light, one or the other each time and it wont dry the dish's anymore...
If the clean light blinks 7 times thats you heating circuit. Test the heater with an ohm meeting to see if it has open. If so order the heater kit and it comes with the control board.
Jan 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Order and replace the front panel only - not the control card. This will resolve the problem.
May 07, 2008 | Dishwashers
Green clean light flashing dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
Nov 22, 2007 | Dishwashers
Maytag 24 in. MDB6100A Built-in Dishwasher Logo
62 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
