Question about Lands Phones
I have an i phone and i have reset it to the original setting, all i get now is emergeny phone calls, i have just got this off e-bay and i do not have the original sim card, and my sim card will not be recognised in the phone now.
  • 1 more comment
  • swanny38 Aug 13, 2008
    when you say take it to the repair center, do you mean take it to a O2 store? or just any phone store?
    thanks for all your help
    Master:
  • 521 Answers
Take it to the repair centre is nessary. as he can insert the orignal sim and can delete that problem which you are facing and make your new sim work properly.it will not be to costly.get it repaired the handset is proper but the settings are faulty.
Posted on Aug 13, 2008
    Master:
  • 623 Answers
You have to take it to a phone tech
  • Anonymous Aug 13, 2008
    to restore it to open line
SOURCE:
Says cannot make the call try again later when giving a voice command using a headset
You might want to restart the device by a hard reset; it shouldn't' take anymore then 1-2 minutes. Hold the power and home button until the phone restarts to show an apple.
Alternativley you can reset your network settings by ->Settings->Reset->Reset Network Settings
Mar 22, 2014 | Apple iPhone 5
I phone
You need to bind the Iphone to the computer you are using.
Aug 15, 2008 | Cell Phones
Atomatic restart in call end time
Try hard booting or resetting your phone to factory settings. BACKUP YOUR PHONE FIRST!!! Doing the following steps will erase the data on your phone.
1. Factory settings reset. In standby, dial *#7780# and the phone`s lock/security code (the nokia`s default security code is 12345). This reset restores phone`s original settings.
2. Menu > Tools > Settings > General > Factory settings
3. Soft reset. In standby dial *#7370# and the phone`s lock/security code.
Sep 11, 2013 | Nokia Classic 2700 Cell Phone
I need to know how to take my SGH A877 out of emergeny calls only. I got the unlock code from at&t but I do not know how to unlock it now.
hi there are many online providers found that render codes to unlock .to purchase codes visit onlinegsmunlock here they send you codes along with the instruction guide about how to enter the codes in your mobile .
Jan 31, 2012 | Samsung SGH-A877 Impression Cell Phone
My "brake" light turned on but my emergeny brake is not on and my cruise control stopped working at the same time. What does this mean?
Check your brake fluid level. Check brake lights. If the cruise sees any sign that you are trying to slow down. ie... any brake input. It will not allow you to set cruise.
May 20, 2010 | 1994 Toyota Camry
Air conditioner 2002 mercury marquis
In the engine bay, there is a set of fuses by the battery. Pop open the fuse panel. There should be a set of relays. Check in your manual under "Roadside Emergenies" for the relays and you will find one for the A/C Compressor. The compressor normally checks out fine, it is a common problem that the relay goes bad. Swap the relay with a new one and you should be golden!
Apr 10, 2010 | 2002 Mercury Grand Marquis
Hello, i`d bougth a iphone on e-bay, and jailbreaked it, now it wont turn on.. What too do...?????
Press the home button and the sleep/wake button to hard reset it. If it doesnt work then keep pressing the home button until your itunes says it's in recovery mode. That will allow you to restore your iphone to it's original settings. Be careful with the 3.1.3 update since it screws your phone up and doesnt let you unlock it. Happened to me unfortunately :(
Feb 21, 2010 | Apple iPhone Smartphone
My iphone was on emergeny call status after upgrading software
UNLOCK YOUR IPHONE FOR ONLY $19 WE CAN UNLOCK IPHONE 3G 3GS 2G, EASY STEP BY STEP TUTORIAL VISIT US AT WWW.UNLOCK-IPHONE.ORG
Oct 13, 2009 | Apple Cell Phones
My ex-friend changed my security lock code on my lg phone intentionally after an argument and she will not give me the code to unlock it. I can recieve calls but I cant call out. Is there some universal...
If the pin has been changed on your security code it usually leaves one option. Visit your Telco vendor or original supplier to have the phone reset back to original manufacturer settings. The downside is you might lose all contacts on your phone (depending on what was locked and the model).
Oct 19, 2008 | Cell Phones
Motorola Razor Phone
First,go to setting,initial set up, master reset,this will delete all your inbox/oubox,or restore to original phone setting..hope it will help...
Nov 18, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Lands Phones Logo
50 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
