Question about Kodak Office Equipment & Supplies
Shortly after I purchased and ran my printer a few times it informed me I needed a new color cartridge. It refused to run on just black which it showed to be about 1/2 full. I just kind of figured I got short-changed on the original cartridge as some company's are known to do, so I went out and purchased a new color cartridge. Now I've only used the new cartridge once and it is now showing and telling me that again the color cartridge needs replacment and refuses to run. What's going on here?
    Master:
    Sergeant:
  • 398 Answers
Go to kodak.com and check with customer support, you may have a warranty problem.
Posted on Aug 13, 2008
I have a Kodak ESP 3250. I always print Black Only, but after a few months I get a 3508 error code telling me to replace my color cartridge. I cannot use the printer, period!!! Since I only print...
If this printer is like some of the HP printers I have serviced in the past, many printers like this use a tiny bit of color as a "primer" to make the black "blacker" and to prevent bleeding in systems where the color is dye and the black is pigment.
A number of printers may allow a "use black only" in the driver settings, but many other printers will simply refuse to print if the color runs out, even if you are printing black and white.
The short answer is, chances are, you need to replace the color cartridge.
Jun 03, 2011 | Kodak ESP 5 Printer
I ran out of the other color cartridges, and just bought a new black ink cartridge only. So can it work without the other color cartridges, and only on the black ink cartridge, because every time I try to...
No many of the printers will need to have both the color and the black cartridges to work...
You will have to purchase and install a new cartridge to get it working correctly.
heatman101
May 17, 2011 | Brother MFC-290C Printer
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to...
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Feb 05, 2010 | HP Office Equipment & Supplies
I use my MX700 only for black & white matters. It sometimes refuses to operate, informing me that my color cartridges have run dry. How do I overcome this?
Unless you have chosen to print in "true black" where only the black ink cartridge is used, your printer automatically will use some inks from the color cartridge to make black. (The reason given is so that your color cartridge will not dry out and cease to function when you do need it for color).
You did not provide your operating system. If you can find your printer name listed in "Control Panel" (usually in "Printers and Faxes"), right click the name and choose "Properties". See if you can find an option to print only using the black ink cartridge.
I hope this helps!
Dec 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
We have long had an HP PSC 750. We don't print in color and a tech person at HP told us just to buy black cartridges and take out the old color cartridge & put it back in and set the printing prefs for...
You must replace the color ink cartidge because the inking system uses both cartridges even on just black prints.
Sad, but true. This is how HP makes their money. Selling ink, not printers.
I'm a good ol' US of A boy.
Jan 22, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
