My computer isn't recognizing my HP Ipaq 3850 it says connect but i cant transfer files or sync anything. It has no folders when i try to open it from the desktop.
  • 177 Answers
Uninstall and reinstall HP.
Posted on Aug 13, 2008
On lumia phone how to transfer pictures to pc
how to video
Nokia Lumia 521 Copy your photos to your computer
  1. Connect your phone to a compatible computer with a compatible USB cable.
  2. On your computer, open a file manager, such as Windows Explorer or Finder, and browse to your phone. Tip: Your phone is shown under portable devices as Windows Phone. To see the folders of your phone, double-click the name of the phone. There are separate folders for documents, music, photos, ringtones, and videos.
  3. Open the folder for photos, and select and copy the photos to your computer. Tip: If your computer's operating system is Windows 7 or Windows 8, you can also use the Windows Phone app. With Windows 7, you can download it from http://www.windowsphone.com/.
Mar 23, 2014 | HP iPAQ hw6515 Pocket PC
HP iPAQ hx4700 need default password
If you can't remember your passcode, you may have to do a hard reset(factory settings) if you have a sync folder on your computer, there is your backup. To do a hard reset: 1. Remove your iPAQ from the cradle, making sure that it's running on the internal battery power. 2. Use the stylus to press down the recessed reset button on the back or side of the iPAQ. 3. While the reset button is held down, press the On/Off button. 4. Release the reset button. When you press the On/Off button again, your iPAQ turns on and all your files are gone. To avoid repeating this major disaster in the future, you should back up your iPAQ files on your desktop PC. Activesync will generate another folder,and you will have to rename your pocket pc. But once your past that point, open both folders and drad and drop into the new folder. Hope this helps.
Jan 25, 2010 | HP iPAQ HX4700 Pocket PC
My playlists from sansa m250 disappeared but when i connected ..
When transfering the songs from computer to player. First, sync device before transfering. Only do this the very first time. If you try to sync with songs already on the player, they will be erased.
To test the device. Open your comuters music file folder, keep folder open, than go to start menu, go to my computer and open the folder (D: or F: folder) It will have your player listed there.
Now with both folders open, take a song from the music folder, drag it to the sansa folder and drop it in there. It should be added to player.
May 05, 2009 | SanDisk Sansa m250 MP3 Player
Won't sync from iPAQ to PC
Sounds like you've got the ActiveSync setting for the Calendar set to one-way from computer to PDA, not Synchronise, which means the computer will always over-write anything it finds on the PDA that isn't in the computer. Try uninstalling/reinstalling ActiveSync, and pay particular attention to all the settings when you reconnect the PDA and it sets up the connection - from memory at this point you can define the "direction" of synchronisation.
Aug 03, 2008 | HP iPAQ rx5915
HP Ipaq h1940 won't sync with Vista
use microsoft windows mobile device center
Jun 11, 2008 | HP iPAQ H1940 Pocket PC
HP ipaq rx3715
Have you tried other SD cards?  The box is uncheck for default install folder?  Maybe update the device.
Oct 13, 2007 | HP iPAQ RX3715 Pocket PC
IPAQ H5500 USB CONNECTION TO PC NOT WORKING
open active sync on ipaq and connect the cable with pc and ipaq. if not recognised perform a soft reset on ipaq. also check in  active  sync on pc >file> connection settings> allow usb connections is checked
Jul 20, 2007 | HP iPAQ H5555 Pocket PC
IPAQ 1715 not recognized
All you should need is Activesync. Try the following... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Sep 08, 2005 | HP iPAQ RZ1715 Pocket PC
H5555 sync problem
When you attach your ipaq, you should be able to go into My Computer and view the ipaq as a removable storage device, seeing the actual files and folders located on your ipaq. I would attempt to transfer the files via copy and past if Activesync cannot do it. If that solves the problem then its simply that Activesync is encountering some sort of memory overflow, if it still cannot sync then there is a problem with transfer protocol its using.
Sep 07, 2005 | HP iPAQ H5555 Pocket PC
Storage Memory
memory card isn't really memory it's more like a disk drive. it's not like when you add memory to a PC and the new memory is automatically used. To make use of this card you need to transfer some of your larger files to the card.... You can move files from within the ipaq... Click and hold on file. Select Copy Click and hold Select Cut Navigate with File Explorer to the SD card.... Open File Explorer Select My device Now select SD Card You can create a new folder or select an existing folder Click on Edit at bottom of screeen. Select Paste. You can also move files directly from PC to Storage card...... While IPAQ is connected, go to My Computer, then double-click on Mobile Device, then double-click on Pocket PC. Now you will see your Storage Card, and you can use this just like a folder on your PC. You can create folders within it. You can click and drag files to it or to any of it's folders.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
