Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Will not dispense water
My frige will not dispense water, It never has. It dosen't make noise. and we get plenty of ice but I wish I could get some water. Someone help!
  • 725 Answers
First remove toe panel...Under the freezer door there is a water line connection.. press in on the outer ring and pull out the water line to disconnect....get a cup to catch the water ... then press the water paddle if water comes out you have a frozen water line in the door.. it no water you have a bad water valve... let me know if it helps
Posted on Aug 31, 2008
Side/side frigidaire not dispensing water & no ice-replaced filter-opened up back of unit- cleaned up- water coming all the way to the frige from house main- hear regular noise like when it wants to...
your double water valve is the problem. solenoid is probably stuck(located on water valve) just replace with new one. water line is connected directly to water valve which is attached w/a couple of screws. hope this helps.
Dec 25, 2010 | Frigidaire PLHS269ZC Side by Side...
Clogged Water Dispensor
The water inlet solenoid is the culprit. It lets water into the icemaker and water for the dispenser. Follow the waterline to the back of the frige and it ends at the water inlet solenoid. Note the 2 solenoids built into 1 part. Replace this part and you are done. Don't forget to unplug frige and turn off the water before you replace this part. EZ FIX...
Mar 29, 2010 | Kenmore 21.7 cu. ft. Top Freezer...
Kitchen aid refrigerator water dispenser does not dispense water. the ice will dispense, and there is no filter for the water, so i would assume no clogging is the issue. But any ideas would be appreciated...
could be a few things. fist, when you call for water, listen for a very faint "hum" noise, if you do hear that, it is either the solonoid on the valve, or the reserve tank in the frige froze. easy way to check. pull the frige out and un-plug from power. on the back of the unit is a cover on the bottom, remove cover. the valve is on the far right as your looking at it. it has 2 solonoids on it. there are two plastic water lines on the bottom of the valve, i believe the one on the left is for ice maker, and the right one goes to door dispenser. remove the water line going to the door dispenser and put a cup under the valve. plug in frige and call for water at the door for couple seconds, check to see if water came out of valve into cup in back. if it did, the valve is ok, if no water, replace valve. they run about $50. if you didnt hear the hum i talked about, and the valve is ok, let me know and i can walk you through checking and replacing the switch in the dispenser. good luck, shane
Aug 24, 2009 | Refrigerators
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
There is a smell from outside the frige
check drip pan for smell see if ice maker lever switch is up for noise
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Re: Dispensing water and Ice
the water valve is located behind the frige, remove the lower back panel and follow the water line from the house to the frige as that line meets the frige that's the valve that may be bad,but before you change it, you can test it, remove one of the 2 lines that goes to the side of the frige and push the switch to get some water, water should come from back there, if not re move the other line, it meant that the first line belong to the ice maker, try the other one now, it should give you water. if not replace the valve.
Mar 26, 2008 | Kenmore 50522 / 50524 Side by Side...
GE Model TFF24RWC Side By Side Ice/Water not Dispensing
I had that issue and a myriad of other issues with my GE side by side fridge. I replaced the control panel $100 and all three problems I had went away immediately.
1. Ice and water dispenser quit working
2. Howling noise 12 hours out of the day
3. Clicking noise
Jan 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Water/Ice Dispenser is not working
Some models need the filter inplace to pass water. First check it again with a new filter in just to be sure the filter isn't clogged. Next... do you hear any click or such noise from the rear of the unit when you push the water dispenser? The solenoid valves may be bad. Also check the valves at the back of the frige to see if the filter screen isn't clogged blocking water from getting into the frige all together. Let us know what you find and post again.
Dec 20, 2006 | Amana ASD 2624 Side by Side Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
77 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
