Question about InFocus LP70+ Multimedia Projector
Projector gives off pink tint
My LP70+ projects a dark rose/pink tint upon the screen. I just replaced the lamp and this does not fix the problem.
  • Mama Anne Aug 14, 2008
    Thank you for the information!
    You are correct, the tint on my projector was not a lamp issue but a connectivity issue. I swapped the cables with good known cables and the tint went away. The projector give off true colors, now. Thank you!
When you have a tint on the projector its not a lamp issue, it is a connectivity issue you have to check the cables if they are connected firmly, or swap the cables with good known cables , if this doesn't help you have to send the projector to infocus repair center, since it is a DLP projector this may require engine /major repair
Posted on Aug 14, 2008
2 Suggested Answers
SOURCE: LP70+ projects a dark rose/pink tint upon the screen
The pink tint produced by my LP70+ projector was not a lamp issue but a connectivity issue. I swapped the old cable with a good known cable and the tint went away.
Posted on Aug 15, 2008
Jvc hd projection tv screen is tinted pink/red PLEASE HELP!!
not so sure if warped lines about it not being convergence, if the lines are diagonal and light red etc it may be a screen circuit issue. Hard to tell from description----take a few good photos and post them on a free photo sharing site and provide a link here---expert who sees what it looks like may be able to help...............
Sep 02, 2012 | JVC Televison & Video
Projection screen is pink
it's the resolution and input issue. make sure that the settings are correct and the resolution matches. then make sure the cable is fine.
Jul 30, 2009 | InFocus LP1200 projector lamp Projector...
LP70 lamp will cycle on and off in 3 min. intervals.
go into the menu and check the lamp hours. if it's over 2000, you need to replace the lamp. if it isn't, the power supply and/or ballast is starting to fail.
Jul 06, 2009 | InFocus LP70+ Multimedia Projector
Aug 14, 2008 | InFocus LP70+ Multimedia Projector
KF42WE60 SONY LCD
Hi Rose Mary
Could you please provide me with the lamp hours on this unit ?
Also take out the lamp and check for any marks or discolouration.
In wich case the lamp will need replacement.
May 06, 2008 | Sony XL-2100U Projector Lamp for...
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Projection Problem with Toshiba TLP 261
If its only in the lower left corner sounds as somethings blocking the lamp from the lcd These sets dont use a degussing coil so we know its not a magnetic problem Check and see if something crawed inside the set and is blocking a bit of the lcd?? ar could be dirt or dust too??
Mar 28, 2006 | Toshiba TLP 261 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
1,355 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
