Question about HP Pavillion ZV6000 Notebook
Hp 6000 notebook screen goes black..... blue control lights go on and off
Hello I have a 1 yr old hp notebook and the blue control lights go on then aftere a few seconds they go off. like its a power thing also the screen stay black seems like the cumputer will not start up barret is goood also plugeg in to 110 so ... what could it be ...soccer mom Cindy
  • mikepandher Nov 12, 2008
    I ahve the same problem - is their a solution?
  • Anonymous Dec 14, 2008
    I HAVE THE SAME PROBLEM
  • 36 Answers
If i'm reading this correctly, it sounds like it could be a motherboard/video issue. If that's the case then unfortunately you are probably going to need a new computer if it's out of warranty...
for now however, try shutting down the computer and removing all power (power cord, battery) for a few minutes, then plug it back in and try to boot.
Posted on Jan 15, 2009
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
Hello Experts, I have a HP Pavilion Tablet Laptop that won't boot. All keyboard lights and monitor lights (DVD controls) illuminate except the actual monitor, it does not come on and is completely...
I'm having the exact same problem on my less than 2 yr old HP Touchsmart tx2675 laptop. Could you please let me know if you have solved the problem?
Thanks and Regards,
Manish
Nov 01, 2010 | Computers & Internet
My 1 yr old son banged on several keys on my laptop and now the screen display is rotated clockwise. Help!
Hi. Try these simple steps:
Press and hold Ctrl+Alt+up, down, right or left arrow keys until you get the screen corrected.
That's all there is to it!
^_^
Jun 08, 2010 | Dell Inspiron 6000 Notebook
Blue Screen, Zig Zag Squiggily lines, black sceen and freezes
No, try to call the HP tech support for possible repair. call at 1-800-474-6836
May 09, 2010 | Computers & Internet
I have a 96 z71 305 4x4, began hesitating while going down the hwy. I have replaced the fuel filter, cap & rotor, catalytic conv., and coil since problems began. Fuel pump is about 1 yr old w/6000 mi....
Hello! The Throttle Positioning Sensor (TPS) is the likely culprit...it is mounted on the throttle body..A round black plastic device with two mounting holes on either side... cost is around $45 It has a three wire connector. The wire colors are; Gray, Black, and Dark Blue.
It can be tested, if you have some experience with a voltmeter..straighten out two paper clips...Push one into the rear of the connector on the Black wire...The other on the Dark Blue...Set the meter to read 5 volts...With engine at idle and connector in place you should read less than 1 volt (about .85)...Slowly increase the throttle...Voltage should rise smoothly to 4 volts...If the voltage skips, jumps or acts erratic the TPS is defective...Send a comment with results....
Guru..........Saailer
Mar 23, 2010 | 1996 Chevrolet K1500
Hp dv 6000 black screen problem
these is small hv board circuit, inside lcd is defective, needs to be replaced. send to repair.
Feb 09, 2010 | HP Pavilion dv6000z 15.4" Notebook Laptop...
Screen goes black after Windows Vista boot
Hello There is chance of serious problem with the screen of the Your laptop. This problem is often seen in case of HP laptop which are more then 6-7 months old. So if the laptop is under warranty they(customer care) will replaced the screen for free. If not the will charge few $ and provide you with original screen. Please check with the vendor from where you have bought your laptop. Regards Gizokieth
Oct 06, 2009 | HP Pavilion dv2310us Notebook
Replaced inspiron 6000 screen with 6400 screen
the screen is bad just look for something to do about it.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
I have a dell inspiron 6000 the screen goes black
the lcd screen may be causing this. Try to connect the laptop to an external monitor and have both working at the same time by toggling Fn F8 on the keyboard. Wait until it goes black on the LCD. post back what happens. If the external monitor wont go out when the lcd does, the lcd may have to be replaced. If the monitor goes out too, it's a video card issue which may be resolved by reinstalling the driver.
Jan 31, 2009 | Dell Inspiron 6000 Notebook
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
HP Pavillion ZV6000 Notebook Logo
194 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
