Question about Electrical Supplies
KAWASAKI 19 hp mtr
I have a Great dane Mower with a 19 hp. Kawasaki mtr. the starter selonoid went bad and I removed it in order to get the right one in my small town. Now I am having trouble getting it wired baack in correctly. PLEASE HELP
5 Suggested Answers
czaa
  • 4514 Answers
SOURCE: Starter clutch trouble on Kawasaki Eliminator ZL600
please dont unless your a pro or from japan the clutch is on the rite or left on engine under a face plate-get a manual or bring to cycle salvage yard-theyre oldschool-it maybe just a simple adjust 0n cable or unit
Posted on Jul 30, 2009
Dolfoff
  • 148 Answers
SOURCE: kawasaki ga1400a generator manual
If it's a Parts Manual you need, it can be found HERE.
I've searched the Kawasaki website (and several others) and was unable to locate a free Owner's Manual.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
Testimonial: "Very helpful. Thank you."
I have a "Workshop Manual" FOR THE ga 1000A/ga1400A. If you are close enough to me it could be copies. I live in Pembrokeshire. My e-mail is alvin.whitticombe@talk21.com
Posted on Jan 06, 2010
huffman49
  • 235 Answers
SOURCE: 19 hp kawasaki carb acting up
sounds like the carb is gummed up from the old gas you will need to clean and rebuild te carb(this is a easy job)...good luck
Posted on Apr 11, 2010
Testimonial: "Thanks. I came to same conclusion but because of limited ability in this area(I'm an electrician by trade)I wondered if I could cheat & spray it out?"
miket756
  • 2702 Answers
SOURCE: 19 hp kawasaki mower motor that dies after operating 45 minutes
well its back to the fule flow,,,i thing the fule lines and carb are blocked up and needs a strip down and a good clean up of all the jets and flote bole this sounds like fule shortage,,,if the engine is only just turning and you try to put it in gear so the cutters start to turn it loads the engine up and it stops!
you say pulling the choke out get it going!!!!! then its short of fule ,,,right!
Posted on Jul 15, 2010
My Kawasaki mule 550 clicks and the starter wont turn over. it has a new battery and selonoid.
It could be a relay clicking. Check with the parts department to find out if it `has one.
Oct 13, 2013 | All Years Kawasaki Kaf300 Mule 500 520 550...
On a 19. hp kawasaki when both coil wires are plugged in, it wont run. runs fine when both are plugged in
the kill switch operate from a ground wire look to see if it is shorted\ out along the path
May 18, 2012 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
Kawasaki 17hp fh500v won't start.
Did you try to use a little starting fluid to get it going. If you did and it would not fire, then you have no spark at the plug. If you did and it did fire, then you have no gas getting to the carb.
Mar 10, 2012 | Garden
Im having problem with my kawasaki rouser,when im starting thers is no movement of the starter thers only a sound of the relay, do u think the relay is broken?
Hi. I believe the selonoid on the starter maybe the problem. If you can bench test the motor to check if it runs. Replace the selonoid and see. Good luck.
Jul 05, 2011 | 2003 kawasaki ZX-7R
Jul 15, 2010 | kawasaki Garden
Apr 04, 2010 | Garden
Electrical Supplies Logo
111 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
