Question about HP OfficeJet 7410 All-In-One InkJet Printer
Error Code on HP Office Jet 7410
What does :
Error : Ox 829ffa30
1: d/FX/MISC/INTENT/.xml
mean??
Computer says USB ROOT HUB unknown device
Printer doesn't respond .
  • jsant Sep 24, 2008
    network printer - will find its panel lights blinking usually with a blank screen. press power button and it will start back up and work for a while. Last time it also showed the same error as FCTX's post.
  • Anonymous Apr 23, 2009
    We had the same error message too. What does it mean and how can we avoid this from happening again? CLP
  • 25 Answers
SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
Preventing paper jams
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Posted on Jul 08, 2008
Inkworks
  • 87 Answers
SOURCE: G 55 Office Jet error code
Are all the lights flashing....probably a main board.
Inkworks
866-381-0541
Posted on Nov 06, 2008
faxman789
  • 297 Answers
SOURCE: HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Posted on Jan 17, 2009
jyackle5
  • 8197 Answers
SOURCE: want driver for hp Office Jet G55 Printer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=57742&
Posted on Apr 08, 2009
FixinFax
  • 3085 Answers
SOURCE: HP Office Jet 7410 paper jam error and there is no
Did you remove the lower rear door and check?
Posted on Jun 27, 2009
The computer can not recognize drive (unknown USB device).
Method 1 - Unplug Computer So how did I finally fix the problem? Well, if you are lucky, it's a super simple solution! Try this method first and if it works, you'll have saved a lot of time.
Simply unplug your computer from the power supply. Yes that is it! Note that this does not mean just turning off your computer using the power button because most modern computers don't actually turn off completely and the motherboard will still get power. This is useful sometimes if you want to remotely wake up a computer, etc.
The motherboard is where all of hardware of the computer connects to, including the USB ports. Sometimes the motherboard needs to be "rebooted" because things can go wrong, i.e. all or some USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should hopefully be recognizing devices again.
So first turn off your computer using the Shut Down option in Windows or pressing the power button and then UNPLUG the PC from the wall outlet. Let it sit for several minutes and then plug it back in.
Method 2 - Update Device Driver If Windows is not able to recognize the device, you may also see in Device Manager that the device shows up as an "Unknown Device". You can get to Device Manager by clicking on Start and typing in devmgmt.msc or by going to Control Panel and clicking on Device Manager.
In that case, you should right-click on Unknown Device, click on Properties, then the Driver tab and then click Update Driver.
If this doesn't work, you can also try to download the driver for your device from the manufacturer's website. If the USB device is just a flash drive, then it's probably not a driver issue. However, if you are installing a USB printer, drawing pad, etc, then it might be worth downloading the driver for that specific device.
Method 3 - Restart & Disconnect USB Devices The next thing you can try is to disconnect all USB devices and then restart the machine. once you have restarted, try to connect the USB device that was causing the problem.
If that particular USB port doesn't recognize it, try another one. If the device is recognized by a different USB port, there could be a hardware problem with one of the USB ports. If no USB port recognizes the device, then keep reading because it's probably something else.
Method 4 - USB Root Hub Another thing you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties.
Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box. If you have more than one USB Root Hub listed, you need to repeat these steps for each one.
Click OK and then restart your computer. Try to reconnect the USB device and see if it is recognized. If not, go back to the power management tab for each one and check the box again. If it does recognize the device, then leave them unchecked.
Method 5 - Connect Directly to PC A friend of mine ran into this issue and the cause ended up being his USB hub. He only had three USB ports on his computer, so he bought a hub where he could connect an additional 8 USB devices.
I guess this proved too much for his computer and it just started sporadically not recognizing various devices. After removing the hub and connecting the device directly to the computer, it worked just fine.
We haven't really been able to find any other solution to this problem other than reducing the number of items connected to the hub. Actually, one other solution worked, but it meant having to buy a new USB hub with more power.
If you are having this problem with Windows 8 or Windows 8.1, then you might be in luck. Microsoft has released a fix for Windows 8 not detecting USB devices properly. Make sure to install this hotfix if running Windows 8.
Method 6 - USB Troubleshooter If nothing has worked so far, you can download the Windows USB Troubleshooter Fixit tool. It's a free tool that works with Windows XP, Vista and 7.
You can either have the troubleshooter fix the problems for you or select the fixes yourself. I would just let it fix them for you since the choices can sometimes be confusing and technical for the novice user.
Method 7 - Update Generic USB Hub If you are getting the Unknown Device error in Device Manager, you can also try one other thing. Open Device Manager and then expand Universal Serial Bus Controllers.
You should see at least one item called Generic USB Hub. On some computers, you might see two, three or more of these. Right-click on the first one and choose Update Driver Software.
When the update dialog pops up, choose Browse my computer for driver software.
Jul 10, 2015 | Transcend StoreJet 25 750GB USB Hard Drive
Free download HP director for HP Office jet 7410
the hp support wesite should have it---if not, try driverguide.com
May 08, 2010 | HP OfficeJet 7410 All-In-One InkJet...
I have a hp officejet 5610 all in one printer/fax. everything was fine until now. when i scroll to help,an error comes up "there is no computer connection refer to device documentation". i checked all...
It's may be a microsoft bug on usb 2.0...
Go to device manager \ universal serial controllers \ expand \ usb root hub properties \ power management tab \ uncheck the box abt turning off...
Feb 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
Non of the 3 USB ports works anymore for unknown reason
ok, the answer is pretty simple, ur usb ports connect to a internal hub, that hub is what has malfunctioned, u need to reinstall that device's driver though the device manager on vista, go to start, type device manager in the search box, click device manager in the list, a uac query will appear, click continue, on device manager go to universal serial bus controlers and click the +, right click the usb root hub and uninstall it, repeat that for all of the usb root hubs, then restart ur pc, it will automatically reinstall the devices with a fresh driver, plug in your usb device and it should work, have a great day and happy holidays
Dec 31, 2009 | Toshiba Satellite A135-S2276 Notebook
I replaced my old HP office jet 7410 all in one with another one that has the same model but I can t print.
first of all i would like to know..how is the printer connected..is it connected through USB or WIRELESS..
please let me know..so that will provide you some steps..
Mar 10, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Printer won't print.
If the cable you are using is USB.
Try these steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : HP Office jet 7400)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get pop up "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Mar 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Critical error 678
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpia2302
http://support.microsoft.com/default.aspx?scid=289706
1) make sure you have the latest active sync installed
C:\Program Files\Microsoft ActiveSync\drivers
or
c:\windows\system32\drivers....with activesync 3.7 anyways.
2) go to contro panel -> system -> device manager -> view device b
connection -> plug and play bios -> pci bus -> usb host controller -usb root hub
3)delete everything uner usb root hub.
4)from control panel run add new hardware
5)now everything under your computer's usb hub including the cradl
will be installed properly.
6)once this installation is performed, you will make sure to see "H
USB Sync 1620" under USB root hub
Jan 17, 2008 | NEC MobilePro 900 Handheld
HP OfficeJet 7410 All-In-One InkJet Printer Logo
150 people viewed this question
Ben Johnson
