Question about HP Office Equipment & Supplies
HAVE REPLACED A new BLACK CARTRIDGE SEVERAL TIMES BUT THE BLACK WILL NOT PRINT
  • 35 Answers
It is very possible the black print head is clogged with dried ink.
Begin saving money for a new printer.
Clean the print heads manually:
Remove the cartridges.
There will be small extrusions where you removed the cartridges.  They are the print heads.  These need to be wiped down with cotton swabs dipped in rubbing alcohol.  Keep this up until you can see the miniscule holes in the top of them.  THE CRUCIAL STEP: Take something thin enough to fit in the holes and push it all the way through.  This will clean out the dried ink and you should be able to print now.
Posted on Aug 13, 2008
Our copier (model x5650) stopped while receiving several pages , and displayed FAX IN MEMORY COLOR AND BLACK INK CARTRIDGE NEEDS REPLACED. I installed a new black cartridge , however the display...
YOU NEED TO LET THE PRINTER RE-ALIGN ITSELF AFTER INSTALLING PRINT CARTRIDGES, THE PRINTER SHOULD HAVE PAPER IN IT TO DO THIS, THE TEST PAGE PRINTED WILL THEN NEED TO BE PLACED IN THE PRINTER ON THE GLASS, PRESS SCAN, THIS SHOULS RESET YOUR PRINTER.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Lexmark C533DN InkJet Printer
Just replaced black cartridge in my 2600n color laser. I have smudged about a half inch wide 2/3rds over the right of each page. It only smudges in black. I have recalibrated several times. Printed at...
If this just started after you replaced the toner cartridge, one would have to say that it is a bad toner cartridge.
Print something that smudges. Pull down the front cover and look at the cartridges. Pay attention to the top one(black).
Look at the drum on that cartridge. You should see the toner sitting there. Compare it to the other cartridges which should be clean.
Feb 08, 2011 | HP Color LaserJet 2600n Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
I replaced the black cartridge and the machine asked me to align.. I have done this several times and the machine will still not print in black. What do I do?
You might have to remove a strip first that comes with the new ink cartridge. Or, perform the function that cleans the printer heads
Hope this helps. :)
Oct 02, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Replaced ink cartridge 56 and black print text is
Remove the cartridge and use a damp paper towel, wipe the bottom of the cartridge several times. Each time you wipe you should be getting black streaks on the paper towel. After manually cleaning the cartridge nozzles you will need to use a new tower and wipe the contacts on the back of the cartridge. When this is done reinstall it and run a cleaning and then an alignment procedure from the printer software. You should be printing good again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to...
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Feb 05, 2010 | HP Office Equipment & Supplies
After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Aug 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Apr 10, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
44 people viewed this question
Ben Johnson
