Question about HP Officejet 5610 All-In-One InkJet Printer
Hp 5610 all-in-one not printing
My mom's all-in-one printer is not printing online or offline. did a self-test and the printer itself prints. went to printers and faxes, right clicked to set to online and it changed to ready. then it would mysteriously go back to offline when i checked again. tried to print by going to the document queue and that did not work either. tried to download the driver and it said that the newest version was already on this computer. called hp and they want almost half the cost of a new printer to fix the problem, since the machine is out of warranty. feeling somewhat raped at the moment. the fax, scanner and copier all work. any kind hearts out there with knowledge of a solution to this issue??? can we get her current machine up and printing again??? thanks!!!
cheers,
~~~gary~~~
  • 1 more comment
  • gary miller Aug 14, 2008
    thanks tech and cindy. turns out that the cable company had been tinkering with her equipment. he had plugged the usb cable back into the computer, however, there was a connector cable which took the usb far enough to reach the printer. he never connected that portion back. what a knucklehead. anyway, thanks again so much for the immediate response. you have a great community here. will pass it on to friends!!!
    cheers,
    ~~~gary~~~
  • bj-dwp Mar 31, 2009
    5610 printer reading offline and will not print
  • Anonymous Mar 31, 2009
    no imprime
  • HP Master
  • 5,218 Answers
Is the printer directly connected to the computer or is it plugged in to a USB hub or print server? If it isn't directly connected to the computer, try plugging the USB cable directly into the computer. You should get a new hardware found message with plug-and-play Windows versions. If that doesn't work I'd suspect a bad cable.
If it is directly connected to the computer already, I've found many USB printers need to have the cable removed from both the device and the computer to reset the printer. (wait ~5 minutes before plugging things back in). This is also true with print servers and USB hubs but you're halfway there going to the direct cable connection.
Did you see any small files listed in the printer queue when you tried to print from there? You may want to clear the spooler. From the command prompt issue the commands "net stop spooler" and "net start spooler" without the quotes. You can do them from the Start Run command as well.
I hope this helps.
Posted on Aug 13, 2008
    Sergeant:
  • 359 Answers
Have you deleted the printer, uninstalled the drivers and related software from add/remove programs, reboot the machine, redownload the drivers from their website??
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
23
Posted on Apr 05, 2009
When i print from hp deskjet D1560 it dose not print. It automatically shows offline when i print even though it is not offline. And it dose not print self test page also. pls give an instant...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 19, 2011 | Office Equipment & Supplies
HP officejet 5610 does not print - Is it due to it showing offline? How to turn it ONLINE so that it may print?
Please follow below steps to make the printer Online
  1. Click Start ->Control Panel ->Printer and Faxes
  2. Right Click on the printer.
  3. Select "Use printer Online"
  4. Now your printer will be online for printing.
Please reply back for any queries.
Regards
Riztech
Jan 10, 2011 | HP Officejet 5610 All-In-One InkJet...
My printer is ofline and it want print
Make sure the physical connections are correct.Then go to control panel and right click the printer and make it online
May 03, 2010 | HP Officejet 5610 All-In-One InkJet...
Hp 5610 all in one printer, cartridge error, will not print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
abdsf17
Aug 10, 2009 | HP Officejet 5610 All-In-One InkJet...
HP psc 2410 xi went offline on its own. I checked
you may have to add another print driver
if you still have the cd try to add a device from the cd if not you may either have to uninstall and reinstall software or add a printer in your control panel in either printers or printer and faxes--win xp
Jun 28, 2009 | HP Office Equipment & Supplies
HP Officejet 4315 All-in-One went offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Officejet 4315 All-in-One Printer
Printer Connected but wont print
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
Nov 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer problems
Hi Huges,
Have you tried printing an self test page from the printer itself,
if no then,
Press setup,
Use the arrow keys and go to the option that says print reports,
then press ok.
then go to the option that says self test report, and press ok.
If the unit even does not print this then it might be an issue with the unit, check the display on the machine and then reply me back.
Regards
Santhosh
Bye
Nov 07, 2007 | HP Officejet 5610 All-In-One InkJet...
Printout blank
Hi Seng, Run a self test from the printers control panel. 1. Press the printer?s ON LINE button to take the printer offline. 2. Press the Control Panel MENU button until TEST MENU appears on the display. 3. Press ITEM until SELF TEST appears on the display. 4. Press ENTER. The Self-Test will print. 5. Press ON LINE to return the printer to the online state. If it prints than you have a software issue if not it's hardware. For Software Check the Density Settings. Make sure it's not set too light. Also try printing from another app, maybe you have a corrupt print job. If you have a hardware issue come back here and I'll help you sort through those. Let me know, Dude
Nov 23, 2006 | HP LaserJet 4 plus Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
1,441 people viewed this question
Seeker5211
Seeker5211
