It
will not let you unlock the door because the machines full of
water?--the machine will not finish its cycle because the vacume switch
is still detecting water. The water will not drain because the pump is
blocked with something , probably a wire from your underwire bra, all you
can do is undo a pipe undernieth and let the water drain away and take
the pump to bits? There may be an inspection cap somewhere on the front
at the bottom.
Hope helps.
