Calculations in Adobe 8.0
I am trying to do division in my PDF document. Any suggestions, I see where you can add and multiply but not divide or subtract.
Thank you
    Scholar:
  • 132 Answers
Are you using live cycle (Part of Adobe 8)
On the RAW form - select from main bar - Window, Script Editor
Your Addition or Subtraction will be :
Field 1 + Field 2 or Filed 1 - Field 2
For division, change this to Field1 / Field2
For multiplication, Field1 * Field2
I have a PDF (Created in Livecycle that calculate standard deviation in tabular format) - currently working on the graphical representation
Posted on Aug 18, 2008
SOURCE:
6 divided by 2/3 + 1/2
First add 2/3 (4/6) + 1/2 (3/6) = (7/6) = 1.1666
6 divided by 1.1666 = 5.1431
Oct 03, 2017 | Office Equipment & Supplies
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
Can you help me on this question?
This answer is correct. 4/12 divided by 2/2= 1/3
The reciprocal of 2/2 is 2/2
Then you multiply straight across and reduce to get 1/3
Mar 01, 2015 | Miscellaneous
1.71 to 4.56 ratio simpify
1.71/4.56 ratio simplified.
First, let's clean it up by multiplying top (numerator) and bottom (denominated) by 100. Now we have 171/456.
Next, I use an old trick. If you add up the digits in a number and the answer is divisible by 3, the number is divisible by 3.
1+7+1 = 9 and 9 is evenly divisible by 3, so 171 is divisible by 3.
Similarly, with 456, 4+5+6 = 15 and 3 goes evenly into 15, so 3 goes in evenly to 15. Alternatively, we can take the answer 15, and go 1+5 = 6 and 3 goes evenly into 6 so 3 goes evenly into 456.
171 ÷ 3 = 57
456 ÷ 3 = 152
Since is 57, 5+7 = 12 and 1+2 =3, 3 goes into 57 19 times.
Since 152 is even, factors are 2 and 76. Factoring 76, 2 and 38. Factoring 38, 2 and 19. So 152 is 2 x 2 x 2 x 19.
Since 19 is common, we can divide top (numerator) and bottom (denominated) by 19.
57 ÷ 19 = 3
152 ÷ 19 = 8
Thus, the final answer is 3/8.
Alternatively, you can factor 171 and 456 and divide by the highest common factor, which are the factors that are common to both.
Feb 22, 2015 | Office Equipment & Supplies
What are 4 different fractions that are equal to 1 1/2
Hi Anonymous,
You can make equivalent fractions by multiplying or dividing both top and bottom by the same amount, but only multiply or divide, never add or subtract, to get an equivalent fraction.
I've only shown the fraction part of your question as 1 is a whole number.
1/2 = 2/4, or 4/8, or 8/16 or 16/32 or 32/64 & so on.
Going the other way, dividing 2/4 by 2 will give 1/2.
But, only divide when the top and bottom would still be whole numbers, for instance you wouldn't use divide for odd number fractions, for example 1/3 or 3/5 etc.
Trust this helps, best regards Alan
Feb 11, 2015 | Office Equipment & Supplies
What is 67,872 divided by 24, step by step?
First, find out how many whole times 24 will go into 67
67/24 = 2 with a remainder that we don't care about. Write down 2
Next, multiply that answer (2) by 24 2 X 24=48
Subtract that 48 from 67 67-48=19
bring down next digit (8) append to the19 198
divide 24 into 198 198/24=8 Write down 8
multiply that answer by 24 8 X 24 =192
Subtract that 192 from 198 198 - 192 = 6
bring down next digit (7) append to the 6 67
divide 24 into 67 67/24 =2 Write down 2
multiply that answer by 24 2 X 24 = 48
subtract 48 from 67 27-24=19
bring down next digit (2)append to the 19 192
divide 24 into 192 192/24 = 8 Write down 8
multiply that answer by 24 24 X 8=192
subtract 192 from 192 192-192=0 You're done!
Your answer is the numbers you wrote down after the divisions = 2848
2 8 4 8
24 ) 67872
- 48
198
-192
67
- 48
192
- 192
0
Oct 15, 2014 | Office Equipment & Supplies
How do you do long division
Let's do an example, outlining all the steps.
528 divided by 6
__88
6)528 does 6 go into 5. How many times does 6 go into 52. So put
48 the 8 above the 2. Next multiply 8 times 6 and put the answer
---- under the 52. Subtract 48 from 52. Write the 4 under the 8 in
48 48. Now bring down the 8 from the 528. How many
48 times does 6 go into 48. 8 times. Write the 8 above the 8
--- in 528. Multiply 6 by 8 and write the answer under 48, and
0 subtract from 48 leaving 0.
Let's check to see if we did it correctly. Does 88 times 6 equal 528? Yes. So we have confirmed that we did it correctly.
Good luck.
Paul
Oct 04, 2014 | Office Equipment & Supplies
How to calculate decimal to octal
step 1: divide decimal number by 8
step 2: write down the residual of division
step 3: if the result of division if 7 or less, write it to the left of residual you wrote in step 2, and there you go, you;ve got an octal represent. If the result is greater or equal to 8 then:
step 4: divide that result by 8
step 5: write the residual of that division to the left of the last one you wrote
step 6: from tis point everything is the same as from step 3.
Example: calculate octal represent of 123
123 / 8=15 , and residual is 3
15 >= 8, so the next thing you do is:
15 / 8 =1, and residual is 7
so far, we have 73
1<=7, so you write it to the left of 7, and there you go, 173 is octal represent of 123.
Hope this was helpful.
if you want to check your calculations, most calculator software has option to automatically calculate octal represents, i.e.
http://www.statman.info/conversions/octal.html
May 21, 2014 | Computers & Internet
Demonstrate how to multiply two binomials
Try to seek these: By using the suggested format:
Suggested su
  1. Adding and Subtracting Binomials
    • 1
      Arrange each term in each binomial in order of degree from greatest to least. The degree of a binomial is the exponent attached to the term. For example, 4x^2 is a second degree term.
    • 2
      Multiply each term in the binomial that is being subtracted by -1 to turn it into an addition problem. For example, the problem (8x^2 + 8) - (x^2 - 2) becomes (8x^2 + 8) + (-x^2 + 2).
    • 3
      Combine like terms. In the example problem, the x^2 terms are combined and the constant terms are combined, yielding (8x^2 + 8) + (-x^2 + 2) = 7x^2 + 10.
    Multiplying Binomials
    • 4
      Understand the F.O.I.L. method. F.O.I.L. is an acronym standing for first, outside, inside and last. It means that you multiply the first number of the first binomial by the first number of the second, then the numbers on the outside (the first term of the first binomial by the second term of the second binomial) and so on. This ensures that both numbers in the first binomial are multiplied by both numbers in the second.
    • 5
      Use the F.O.I.L. method to multiply the two binomials together. For example, (3x + 4)(3x - 4) = 9x^2 +12x - 12x - 16. Notice that -12x is the product of the outside terms and -16 is the product of the last terms, 4 and -4.
    • 6
      Simplify. There will almost always be like terms to combine. In the example, 12x and -12x cancel out, yielding the answer 9x^2 - 16.
    Dividing Binomials
    • 7
      Use the distributive property to divide both terms in the binomial by the monomial divisor. For example, (18x^3 + 9x^2) / 3x = (18x^3 / 3x) + (9x^2 / 3x).
    • 8
      Understand how to divide by a term. If you are dividing a higher order term by a lower order term, you subtract the exponent. For example, y^3/y = y^2. The number part of each term is handled like any other division problem. For example, 20z / 4 = 5z.
    • 9
      Divide each term in the binomial by the divisor; (18x^3 / 3x) + (9x^2 / 3x) = 6x^2 + 3x.
May 10, 2014 | Computers & Internet
I want to know how you convert currency on my normal calculater. do you x by the rate or divide it.
http://www.x-rates.com/calculator.html
check your calculations with the above link
when i was in thailand, the exchange rate was
1 Thai baht = 0.0375 US dollars
since then the dollar has gone down
to go from baht to dollars, multiply
to go from dollars to baht, divide
ex:
1 baht = 1 x .0375 = 3.75 cents
1 dollar = 1 / .0375 = 22.67 baht
ps, that one was easy to do because .375 is 3/8 and i would multiply by 3 and then divide by 8.
but the rate has changed and the world has gotten tougher
Jan 13, 2011 | Casio Office Equipment & Supplies
Open Questions:
Computers & Internet Logo
116 people viewed this question
Ekse
Alun Cox
