Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
No sound ondvi or cmp
When I hook up the cable there is sound, but if I change the input to cmp or dvi there is no sound even though I put the rca jacks in the proper inputs
  • dclassic Aug 13, 2008
    Would the setting be in the menu. I haven't seen it
    Sergeant:
  • 359 Answers
A DVI cable does not transmit sound, DVI is video signal only.
There should be one primary RCA Audio out and you may want to poke around in the settings and make sure it's enabled.
Posted on Aug 13, 2008
SOURCE:
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
Nov 24, 2012 | Sharp Televison & Video
This may be an impossible problem to solve..we just got a Hitachi 51m200 rear projection tv. it does not have an hdmi slot although the tv says it is dvi-hdtv and our cable box is hdmi output. so if i get...
It isn't impossible at all. You may need a sound bar if you don't already have a Bose surround sound system or a boom box or something else you can use without purchasing anything. On the hdmi/dvi televisions and cable boxes of the recent past there would always be an accompanying white and red composite/RCA slot (output on the cable box, input on the television) to accommodate this. You would simply connect the hdmi to dvi cable from the television to the cable box and then the red and white audio cable. If your television and cable box does not have the red and white composite/RCA audio input and output you will need to connect the cable box to an external audio source. How to do it and what to connect it to depends on what audio output that is on the cable box (usually is on the back of it). You might need a fiber optic cable and a sound bar with a digital audio input if you have a newer cable box.
Sep 28, 2010 | Televison & Video
No sound when hooking up DVi to HDMI...
This is normal, when you go from HDMI to DVI, the sound does not get transmitted. You need a separate cable to go from audio output on the computer to Audio input to the TV. There are speaker (headphone on laptop) jack to RCA audio cables, you could also go with digital audio or even optical out if your computer and TV both have the input and outputs.
Oct 05, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
How to hook up xbox 360 to jvc dlp thru hdmi ports
You can use an HDMI-to-DVI cable for the TV's DVI input and this would give you video at full HD 1080p resolution but you need to route the audio via standard red & white RCA. It would be better if it has digital audio inputs such as optical or coaxial to get Dolby Digital and other digital formats from your source.
If in the unlikely scenario that it does not have a DVI input (which looks similar to your PC's blue VGA only wider and is white) you can hook it up to your component video-in (which is the red/blue/green RCA inputs). For this you need a cable that has HDMI on one end and red/blue/green for video RCA's +red/white RCA's audio.
This would give you 1080i resolution with stereo audio.
Hope that helps.
Aug 27, 2009 | JVC Televison & Video
Is there a way to hook up a HDMI connector to my WS-48413
Yes, there are several ways to hook up your HDMI to your TV but first, we need to understand that HDMI carries both audio and video signals though a single cable in digital form.
I am assuming you want to connect a device such as a digital cable box, Blu Ray or HD DVD player with an HDMI output to your TV. Since your TV has both digital (DVI) and analog (S-Video, component, etc) inputs, my suggestion would be to get and HDMI to DVI adapter (about $20 at buy.com) for your video and for your audio, use any RCA audio cable (I use the one from the Dollar Store). This would give you the best video resolution from your source device.
My next suggested solution would be to get an HDMI to component video + audio cable (< $10 at eBay for a 6' length) for a single-cable fix. Again component video carries analog signals so the DVI could be a better viewing experience but because the cost of the cables are minimal, I would try both solutions to see which fix would give you the better picture.
Note that since the audio is being run though RCA connectors in both instances, the digital Dolby, 5.1 or 7.1 surround sound tracks in high definition sources will not be reproduced if you connect your TV's audio-out to your audio receiver. To get the best audio, I would connect the HDMI device's digital out (optical, coaxial, etc) directly to the receiver.
Hope that helps. Have fun!
Aug 23, 2009 | Televison & Video
Motorola DSR505 HDMI problem
Check to see if input 5 has a audio in source via RCA jacks. Many times manufactures will give you multi HDMI inputs but only one that has RCA jacks in case you are running a DVI/HDMI cable. If input 5 does not have those RCA jacks you will not have sound. I know this unit has multiple HDMI inputs. Look to see if any of the other HDMI inputs also have RCA jacks.
I hope this helps,
Skyassoc
Jun 22, 2009 | Televison & Video
Sansui 26 HDLCD DVD Audio DVI/HDMI
Does Sansui HDLCD 19WB have a HDMI outlet
Oct 18, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Picture problem
I have the EXACT same problem with my Sony SDM-P234 23" HD/computer monitor. I know it works (and it works great) with my DVico PCI card with my computer. It outputs in 480i, 480 p, 720p and 1080i with clarity on a simple indoor RCA HDTV antenna. I get the same quality (1080i) picture for the same three seconds as does lewy. I can also add that the digital coaxial output delivers 5.1 audio to my amp and it stays on even after the picture cuts out. Please help.....Comcast sendsa 'technician' out to service it and...well....did I say he's a 'technician'? He changed the box twice and says it must be my equipment. I guess its an act of God that it works with anything else.... I mean....its been checked out by a Comcast 'technician' after all.
Apr 14, 2007 | Arris DCT6200 DTV Receiver
Phillips pf7320 model
if your using the hdmi input you need to make sure you have an hdmi capable input source on the other end if you are using an hdmi to dvi cable make sure you have alternate analog cables hooked up to something that will amplify them or go back to dvi to dvi and rca audio cables make sure the speakers are turned on in the menu
Dec 06, 2006 | Philips 37PF7320A 37 in. HD-Ready LCD...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
