Question about Onkyo HTR500 Receiver
AV Receiver buzzing with nothing connected
Hey there...my refurbished Onkyo receiver buzzes with or without anything connected to it and at various times. It'll be fine one minute and the next it will be buzzing like crazy. The buzz is coming directly from the unit and not going through the speakers when connected.
Can anyone tell me what is going on with it and what I can do to remedy the buzzing?
Thanks!
  • 1 more comment
  • cchilc01 Aug 23, 2008
    I am having the same problem. I have even tried hooking the unit up to my monster line conditioner and I still have the hum.
  • Anonymous Nov 11, 2008
    Me too on a brand new Onyko TX-SR506.
  • chubakka Nov 25, 2008
    I have a TX-SR304 receiver (5.1) and exactly the same problem. Its fine after a long period of not using it. Then all of the sudden after turning it on for a couple of hours it startsbuzzing like crazy
3 Suggested Answers
robotek
  • 1512 Answers
SOURCE: AV Receiver buzzing with nothing connected
Hi
Do you have any warranty on the refurbished unit? I would be first attempting to pursue the supplier that sold it to you to resolve the problem.
If not.... the buzzing is caused by a loose lamination in the power transformer. Replacing the transformer will solve the drama. there are a few things that you can do to attempt a repair.  These are the measures that I have found to  have worked in the past when repairing this sort of problem.
  1. Check and tighten all the casing and transformers mounting hardware/screws. Tighten any screws that pass through the transformer also. Try the amp to see what happens. If still buzzing, onto the next step.
  2. To settle the loose lamination, you can try to "Tap" the outside metal parts of the transformer about the laminations from several different directions   with a ball peen hammer (round end). You could also use a center punch to do this to produce a mechanical dent that puts pressure onto the laminations to resolve the problem.BEWARE- DO NOT HIT THE WINDINGS OR PLASTIC PARTS OF THE TRANSFORMER. The amount of force that you use here is up to you. don't go overboard, and watch your aim, don't hit anything but the transformer. It will often take some "denting" to produce the result we are looking for. Try it and see what happens
  3. Put a spacer under one mounting tab of the transformer to "flex" the casings. You may need to try all corners.
Keep trying different combinations of the above, and hopefully you will be able to resolve it. Sometimes, there is nothing you can do but replace the transformer. I would spend at least 1 hour mucking around with it in the fashion described above, and you should be able to stop the buzzing. , I hope that you get it sorted. I have many times in the past. Good luck, let me know how you get on. Cheers
regards robotek
Posted on Jan 04, 2009
freetek
  • 5568 Answers
SOURCE: Onkyo tx-sr606 receiver buzz
This kind of noise can be caused by a transformer that was poorly made. Iron core transformers are normally 'potted' in a vacuum so that epoxy (or lacquer) is forced into the laminations to prevent them from trying to vibrate with the line frequency.
If you are adventurous, remove the housing, turn on the power and using an insulating probe such as a plastic rod (a plastic picnic knife will work), place the tip of it on any larger parts you see and place the other end behind your ear. This will carry the sound in a more directional manner to your ear. You should be able to locate the source of the buzz.
If you can, and it turns out to be a transformer, it will probably have a metal shield around it so it might not be possible to gain access to the laminations. If the shield isn't ultra tight, you might be able to flow some 'Super Glue' into the cracks and with luck, 'glue' the laminations together. Super Glue (or equivalent) is a good insulator so will not cause any electrical problems but take care not to get it on any plastics that are exposed with the housing on, it will cloud them forever.
Posted on Feb 27, 2010
Right front channal buzzes
Only the one channel buzzes? Did you check the cable of the speaker is it properly rolled?
Feb 17, 2014 | Onkyo TX-DS575 Receiver
Hello. I have Onkyo tx-sr606 home theater
could be a bad soldered joint or loose connector, even a bad earth in the secondary power circuit.
Feb 27, 2010 | Onkyo TX-SR606 Receiver
A couple of weeks after initial setup of my brand new Onkyo XT-SR606 receiver, I noticed a loud buzzing noise that starts up approximately 10 min after the receiver is turned on. The buzzing is definitely...
The "buzz" you hear is a power hum made by the power supply transformer. It's technically called "Lamination hum" caused by the revering of electrical current through the power supply transformer. In some cases the hum can vibrate the chassis causing other loose material to vibrate. If you can, go to your dealer and check to see if other units of this same type typically make a hum this loud, and if not, see if he can solve the problem for you.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
Can't connect subwoofer to onkyo av receiver
you would need a y jack to connect those to the receiver
Feb 16, 2009 | Onkyo HTR500 Receiver
Hi
regards robotek
Jan 04, 2009 | Audio Players & Recorders
Noise ...hum
Open up the receiver. Check the fuse. The fuse protects the circut board from overload.
Aug 11, 2008 | Onkyo TX-SR603X Receiver
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
No sound
Onkyo is a piece of shit! I had the same f'n problem....
Junk...............
Dec 16, 2007 | Onkyo TX-SR604 Receiver
Speakers started buzzing.
It sound like your getting AC noise, chances are you have some dried out capacitors
Dec 13, 2005 | Aiwa AV-DV70 5.1 Channels Receiver
Onkyo HTR500 Receiver Logo
93 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
