Question about Dryers
I have a swith and an outlet in one box I connected the juice from the outlet to the swith and every time I turn off the swith my circuit braker goes down. How do I fix that?
  • 706 Answers
If your circuit breaker trips when you flip the switch to the off position you have a short. I would encourage you to contact an electrician to correct that problem before you cause damage to the product you are trying to control, yourself or your house.
Posted on Aug 14, 2008
Where can i find the fuse boxes in my 1985 chevy executive rv, the house fuse box?
I have a 89 Tioga and it is on the base of the bed. The why would be too much juice for the circuit.
Nov 14, 2016 | RVs
How do i fix my proseries water pump
unplugging it while it was runnong shouldn't damage it, probably just the circuit braker. check to see if there is a button or some type of circuit braker on the unit and reset it, if it does not have one check the circuit braker that supplies it power. (in your braker box)
Jun 23, 2014 | Pool & Spa
I have a electrical problem in my 200 AMP murray braker box.It was put in around 1975.It looks like the 200 AMP main breaker is arcing.When the fridge starts the lights go dim..Will another braker work?
The best answer I can give is a new breaker might solve the problem.If the arcing has not damaged the bus bars where the main breaker is connected. Be sure to check to see that all connections are tightened properly. If you are using aluminum wire be sure to use a deoxidizing compound. Tighten the aluminum connections, wait a while, and recheck tightness.
Hope this helps.
. Bob
Nov 06, 2013 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Starts fine...no juice....sat for 10 years in the box...started using it 3 weeks ago...worked fine until yesterday....starts...runs..no juice...no circuit breakers blown...what's up?
Colemans were known for losing what is known as "residual magnetism", especially when sitting for long periods of time without use. This residual magnetism is necessary for exciting the field to produce electricity. Here is what you can try: Plug a 110v drill into one of the 110 outlets. While the engine/generator is running, with an open hand (not fingers wrapped around it) spin the chuck while holding the drill trigger in the run position. Many times this small amount of current that will be produced by spinning the drill motor will restore the residual magnetism and excite the field. Keep in mind that if this works, the drill motor will begin to spin immediately since it is plugged into the outlet. Hope this helps.
Mar 04, 2011 | Coleman Powermate Powermate 5000W...
I can't seem to get my T5225 combo outlet to work. I connected it as directions said but only the light switch works, I tried changing it around & the outlet only works when the light switch is turned...
Electricians don't guess, they test.
Remove device.
Separate wires for testing.
Use ordinary 2-prong tester.
Tape wood sticks to tester leads to keep hands away from power.
Turn on power.
Test each wire to bare ground wire.
Tester will light up on Hot wire. This wire connects to dark-colored screw.
Hot is identified.
Now test Hot wire to each other wire in box, including white wires in back of box (exclude bare ground wire)
Tester will light up on Neutral wire. Neutral wire connects to silver screw. This will complete circuit to receptacle part of device.
The last wire goes to Load (light). This wire connects to brass-colored screw, and will complete circuit to light..
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps shown above for a price.
Dec 24, 2010 | Leviton 5225WSP Switch and Outlet
The red 20amp braker at the bottom of my box keep berking with only a small amont of things pluged in. Any part of the house THE SAME BRAKER brakes . is that right? The same braker?
sounds to me that the breaker is getting weak,try replacing breaker with new one,if it still trips then you have electrical problem in a circuit.
Dec 20, 2010 | Sylvania Circuit Breaker - Zinsco/ RC 20...
Cooper Industries Cooper Wiring 274W Switch and Outlet I need help installing this switch/outlet combo...I have 3 wires...a black, a red, & a copper. I hooked the copper to the green terminal, the...
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Dec 08, 2010 | Cooper Industries Cooper Wiring 274W...
I have a 1990 Toyota Celica. The passenger side
they ussually have a circuit braker, some times built into the switch sometimes circuit braker is in the fuse box. also look under the hood for a burnt fuse link. yhey are usually in a little plstic box mounted on the fender
Jun 29, 2010 | 1996 Toyota 4Runner
I am in British Columbia, Canada. I am trying to move a ceiling light back to its original box. I can connect the wires so that the light goes on, but I cannot control it using a light switch. The box has...
I had a difficult time following your explanation of which wires worked. Therefore I would approach the problem in the following manner. First make sure your electricity is off. Get a voltmeter and determine which pair of wires (one white, one black) go to your ceiling light. You can check continuity from the light socket to the wires in the box on the wall. This will be one side of your circuit on the switch. Then turn the electricity on and determine which pair of wires have electricity flowing to them. Be careful here as you are working with live wires. The remaining pair may run to another outlet and should not have any juice going to them. You may want to check and see if all of your nearby outlets function. If an outlet does not function, you will have to tie these wires together with the ones providing the electricity. Be safe and good luck!
Mar 09, 2010 | Hammering
Dryers Logo
44 people viewed this question
Top Dryers Experts
