Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Front dispenser On GE stainless side by side
I have a 2 year old side by side GE Profile, it makes Ice but nothing on the door works When you engage the dispenser ice or water it does nothing but will kill the light inside and also the fan, please advise
  • 1 more comment
  • ckesh Mar 01, 2009
    mine does not turn off any other lights, sometimes there is no noise and sometimes I get some functions out of the dispenser features
  • rmyrie Mar 03, 2009
    Icemaker works but water & ice dispenser doesnt nor any buttons on the exterior panel.
  • charmon5 Apr 01, 2009
    It makes ice and shoots out water but will not dispence my ice cubes!
  • 74 Answers
Could be the connector at the bottom of the freezer door corroded but it could also be the main PCB failing as the low voltage power supply may be dropping out . By the 'light inside' do you mean in the dispenser or inside the fridge ??
Posted on Aug 28, 2008
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice dispenser does not work and water dispenser works rarely.
the solenoid fell off, where does it go, it must regulate crush ice vs cubed ice. everything works except this
Jul 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
Water and Ice dispenser quit functioning
the solution to this problem is so simple it makes me laaugh out loud. the bulb in the door that illuminates when a glass is placed under the water dispenser draws too much current when it gets old. just remove the bulb and it will work fine. you can then replace the bulb whenever you find it at a hardware store. I had the same problem, and spent hours online looking and was ready to buy a new motherboard to fix it. I have alot of faith in GE, and all of the bashing is a horse ****. GE makes turbine engines that power alot of the airplanes we fly in and i think they know a thing or two about engineering.
Jun 10, 2009 | GE Profile¿ 26.5 Cu. Ft. Stainless...
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
199 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
