Question about Samsung SGH-e315
Forgot password for lock
I switched the sim card from another phone to this one and now i forgot the lock # and im not sure what tot do
  • sky_fire_423 Aug 13, 2008
    im not sure what really to do =(
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile shop and ahve them reset the code for you
Posted on Aug 17, 2008
SOURCE:
I forgot my Phone Lock Password, how do i reset the phone to it's default setting?
Hello here is how i unlocked mine, info provided by Samsung,start by turning the phone off then removing the sim card,
switch the phone on without a sim card,
type in dial *2767*2878# then wait for it to reset!
once it boots up itself, the phone code is now removed and unlocked , you can now shut it down reinsert the sim card and voila!
Apr 08, 2014 | Samsung B2100 Cell Phone
Hi i have a omnia i900 and i forgot may password i think because when i try to type my passwrd at start up it does even react after i press on unlock.some times it tells me passwors incorrect but most off...
If you do not remember the password for your privacy lock / phone lock then you will need to master reset the phone and that will reset the password back to the default password 00000000 (eight zeros). Please follow the steps below...
Steps to Master Reset the GSM Phones to company default settings
NOTE: Following the steps below will delete everything from the phone memory like contact numbers, images, music, messages.
1. Switch OFF the phone and take the SIM card out.
2. Switch it ON without the SIM card, the phone will say “insert SIM card”.
3. Enter the code *2767*2878# and wait for 10-20 seconds until the phone restarts automatically.
4. Now the phone will say “insert SIM card” again, put the SIM card back in and switch it ON.
Aug 20, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Forgot password
This will reset the phone's settings to factory default. Use this at your own risk:
1. Switch off phone.
2. Remove the sim card.
3. Turn on the phone.
4. Type *2767*2878#
5. Use 00000000 when it ask you again for the phone lock code.
Jul 22, 2009 | Samsung SGH-D900 Cellular Phone
I forgot the password of micro sd card
better u download elock or ilock software from net in jar format..use tat software and lock ur folder
Jul 03, 2009 | Nokia 6233 Cellular Phone
I forgot password on samsung sgh j210.. it as
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures. j700 unlock method Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below: Do a custom reset: *2767*2878# once this has finished rebooting turn the phone off. Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter), Turn on the phone - you will now see an "Insert SIM" message, Now perform a full reset: *2767*3855# When the phone powers off, quickly push the SIM card fully in, and let the phone power back up. After you do the reset, check and make sure that your Network lock is active by pressing *#7465625# If it isn't active you must use this code to reactivate it: *7465625*638*00000000*00000000# Then you have to deactivate the SP lock first. To do that you need to input: *7465625*77*00000000*00000000# (this will reset the lock) Then you enter: #7465625*77*00000000# (to disable the SP lock). Then you disable the Network lock: #7465625*638*00000000#
Mar 28, 2009 | Samsung SGH-J600 Cellular Phone
How will i have a code on my n70?
well, you can choose to use a 'PIN code' or a 'Lock code' or 'Memory card lock'
1. PIN code actually locks up your SIM card, so anywhere you put your SIM card, the message on your SIM card will not be read by anybody without knowing your password. It'll ask you password each time you switch on your phone, but after switched on, it'll not be locked anymore, so anyone can read your phone after switched on.
2.while Lock code, locks your mobile phone like 'keypad lock', the different is, instead of just pressing , left softkey and * button, you need to put password on it (it lock after certain idle time - or you can choose to lock it anytime you want by pressing the on-off switch one time (don;t press too long) and choose the belowest which said lock phone ). this type of lock is commonly used.
3.Memory card lock, locks any application which access your memory card, such as images, text, songs, data that is stored on your memory card. but this type of lock, often bring troubles when the memory card get corrupted. so I suggest number 2 type of lock (lock code)
WARNING!!! all password should be remembered, as if you forgot those password, no body can help you unless technician.. see those articles which people post when they forget their password, so you know the risk and the consequences. But they're actually safe as long as you remember ^^
Good luck, all the best!!
Nov 16, 2008 | Nokia N70 Cellular Phone
Forgot my security code
your phone has to be full factory set... doing this, it will remove the security code as well as the data saved in your phone, eg; photos,contacts,msgs,
but im sure it wil help you a lot.....
remove your sim card and memory card, then, press #3 button,* button,call button and power on switch at the same time for about 10 seconds, then wait untill it reboot... then you got your phone fully restored..... security code removed..
sexy-ym
Sep 04, 2008 | Nokia N70 Cellular Phone
Forgot lock code nokia n73
i lost my lock code how to clear it
Mar 27, 2008 | Nokia N73 Cellular Phone
Forgot my lock code for N73
you need to have a master reset code to reset all the settings. I do have an unlocker for this. if you want just give me the IMEI code and I could process it for you FREE.
Feb 26, 2008 | Nokia N73 Cellular Phone
Phone lock needs unlocking - samsung g600
type in *2767*2878# WAIT for it to reset,
once it boots up itself, the phone code is now gone,
if the phone is asking for a SIM LOCK password
then send it to someone who has the equipment to unlock it
Feb 01, 2008 | Samsung SGH-D600 Cellular Phone
Samsung SGH-e315 Logo
43 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
