Question about Dryers
Replacing bearing on Kenmore/Kelvinator stackable dryer that is causing squeaking
  • 1 more comment
  • NGD692 Aug 13, 2008
    Model Number: 417.93812200 How do you access the bearing?
  • Gary Davd
    Gary Davd May 11, 2010
    you will need to go to www.sears.com to get the servical manual I dont have any on their models 417=fridgairs made but need the styles front load top load what do you have and what is your email
  • Gary Davd
    need model #
4 Suggested Answers
  • 184 Answers
SOURCE: squeaky dryer
IF THE LINT FILTER IS LOCATED ON TOP OF THE DRYER,
THERE ARE TWO SCREWS UNDER THE LINT FILTER THAT NEED TO BE REMOVED. REMOVE THE LINT FILTER ALSO.
PULL FORWARD AND UP ON THE DRYER TOP( NOT JUST THE CONSOLE) AND DISENGAGE THE TOP FROM THE FRONT. THERE ARE HINGES ON THE BACK OF THE TOP JUST PIVOT IT UP OUT OF THE WAY. NEXT, THERE ARE TWO 5/16 HEX HEAD SCREWS INSIDE THE DRYER NEAR THE TOP IN EACH CORNER THAT HOLD THE FRONT TO THE SIDES. REMOVE THEM AND THE FRONT WILL PULL FORWARD. IT IS HINGED AT THE BOTTOM. LIFT IT OFF THE HINGES AND SET IT ASIDE. YOU CAN NOW UNDO THE BELT FROM THE MOTOR AND IDLER AND USE IT AS A HANDLE TO LIFT THE DRUM OUT OF THE CABINET.
THE DRUM SUPPORT ROLLERS ARE LOCATED AT THE REAR OF THE MACHINE AND CAN BE REPLACED AS A SET. THE NUMBER IS 349241T FOR THE TWO PACK.
CLEAN THE SHAFT WITH SANDPAPER BEFORE INSTALLING THE NEW ROLLERS. THEY ARE HELD ON WITH TWO TRIANGULAR CLIPS. JUST CUT OR BREAK THE OLD ONES. THE NEW ROLLERS COME WITH NEW RETAINING CLIPS.
AFTER REPLACEMENT, REASSEMBLE IN REVERSE ORDER.
Posted on Apr 08, 2008
kachbibi1
  • 979 Answers
SOURCE: Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Posted on Jan 25, 2009
SOURCE: Kenmore stackable washer dryer. Dryer buzzer is
I just did this; Zard's solution was not quite the same as mine. After removing the control panel (will drop and hang once you pull down on the two spring loaded posts), I located a part that looked like this:
There were two black leads hooked to it. I simply disconnected them and taped the tips with electrical tape.
Voila. Annoying buzzer is gone (detached).
Posted on Mar 03, 2010
Kenmore stackable dryer squeaks So loud. How can I fix this.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
May 18, 2014 | Dryers
Kenmore stackable wash/dryer Dryer squeaks so loud. How do I stop the squeak.
You probably have a bearing in one of the rollers that spin when the dryer is turning. You'll have to take the front panel off and remove the dryer tub by taking the belt off. You'll then see two doughnut shaped wheels attached to the back panel. Check and see if one or both are loose on the shaft that holds them. If they are replace them. Lubercating is not an option. If they seem ok, check the wheel that the belt loops through and make sure it spins without wobbling. One of the three things is causing the squeak.
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
Kenmore 417.84042500 stackable gas dryer. Started
It sounds as if the bearings in the dryer have gone bad. The same thing happened to my dryer.
Oct 22, 2009 | Kenmore Dryers
Squeaky Kenmore Dryer
The idler rollera and belt tensioner have got bearings. One of them is failing.
Jul 07, 2009 | Dryers
Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Mar 07, 2009 | Kenmore Dryers
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
141 people viewed this question
Top Dryers Experts
