Question about Watches
Question Have you found out where to obtain a replacement screw for the Love Bracelet yet?
The bracelet came off my watch.i need the narrow attachment.where do i get one?larry
Posted on Aug 30, 2008
How can I obtain a the bracelet pin that holds the bracelet to the watch base? I currently have the pin but have had the set screw that holds the pin to the watch base come and is lost.
Well if its a spring-bar you're looking for you can generally find assorted sets fairly cheap on ebay....if you need a screw pin you could try ebay or possibly a radio-shack? I think I've found smaller screws there before generally used in small electronics.
May 06, 2013 | Kenneth Cole KC3485 Wrist Watch
Kenneth cole watch
many jeweler have drawers full of spare parts like that. watchmakers too. if you strike out at a jeweler, ask who they use to service their watches.
May 06, 2013 | Kenneth Cole New York Automatic Bracelet...
How do i get links out of invicta Corduba Swiss Chrono?? do they screw out??
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes
Apr 03, 2011 | Invicta Watches
Need a replacement bracelet for slazenger slz8a
There is no other way to obtain Slazenger bracelet, but to contact them. Here is the link: Rate me, plz.
Mar 10, 2010 | Watches
How do you adjust the band on a rolex watch
Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
I need 1 screw for 18 kt yellow gold Cartier love bracelet
Generally watch repair shops will have a great selection of screws and should be able to provide you with a solution. You can also try some of the better repair houses online. I would call first and be ready to provide the case back number from the watch as this is how they match up parts and their availability.
Sep 22, 2009 | Watches
I want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Dec 13, 2008 | Rolex Watches
Rubber bracelet broken
Contact Skagen on line and provide the model number of the watch that should be found on the case back. They should be able to provide a replacement.
Nov 04, 2008 | Skagen Watches
Lost a screw in my cartier yellow gold love bracelet
u can get it from ebay sir
please be in detail
Jun 19, 2008 | Cartier Watches
Tissot T-Touch T33.7.788.51 Bracelet replacement
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
Feb 19, 2008 | Tissot T-Touch T33759851
Watches Logo
359 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
