Question about Kenmore 62602 Electric Dryer
Push the on button but nothing happens but the repeated beeps
You solution of replacing the switch might work for me. How do you replace it? does it come out the front?
And if it was not the door switch, would the dryer start when I push the switch in while the door is openned and then I push the on button?
Thanks,
A husband with a long list to do.
  • 639 Answers
Peace
ngfam1 at your service,
Yes!
If it is not the door switch,the dryer will start when you push the switch in while the door is opened and then you push the on the start button?
Many people every year die form trying to repair appliances they are not experienced with!
Life is worth more tahn a $75. service call!!
Be safe! Bless You!!
If this tasks does not remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
***PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!***
Posted on Sep 02, 2008
Dryer wont start.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Oct 30, 2014 | Dryers
I cant reinstall windows 7 on my lenovo thinkpad t61, during the process it says required cd/dvd device driver is missing. The reason im reinstaling is that i used the startup repair now evrytime i switch...
Are you using a Win 7 DVD? If so there is a repair section and a Load drivers section if you haven't tried yet. Does you computer have a recovery partition? Have you tried to "Cold-Start" the laptop. Remove AC plug, remove battery, hold down on/off button for 10 sec. ,replace battery, plug in AC, push on/off button and repeatedly tap F-8 until you hear a beep or get a response. That's a good place to start.
Nov 01, 2012 | Computers & Internet
Hello, Everytime I press a botton on my viper alarm remote I keep getting this beeping sound a couple of times and nothings happening. What can I do?
what you need to is push the button on the back and hold it until it beeps. then press the lock button and let it sit there until you hear a long beep. then it should work
Jul 25, 2010 | Remote Start System
Pushed a button but dryer does not start, can not push any other
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 12, 2010 | Kenmore Elite HE4 Electric Dryer
Ready remote Brand after market keyless entry remote start the Door lock /Unlock feature wont work when the button is pushed i can hear the unit beep but nothing happens at all all other features work...
that is because the push button pad is broken inside the remote box unit or either it is not making contact with the switch in the alarm remote. may need to replace the push button remote box.
Jul 25, 2009 | 1997 Ford F250 SuperCab
4 wheel drive doesn't work
try replacing the switch in the dashboard.
the two button switch pops out with a litte prying and is easily replacable.
Dec 17, 2008 | 1991 Ford Explorer
Dryer will not start.
Check your door switch. It sounds like the door switch is not engaging (closing properly). If the switch contacts stay open, the interior light stays on the dryer will beep when you attempt to start it. This is the push button toggle switch on the door frame. This is a common symptom of this problem.
Open the door and push in on the switch, If the switch is working properly, the light will go out. If it doesn't, you will need to make sure the switch is not loose. Next, check the wires leading to the switch to make sure they are not loose, broken or grounded to the case anywhere. If all the wiring checks good, you will need to replace the switch. This is a very simple repair. Let me know if you require further assistance. I hope this helps you.
Oct 16, 2008 | Whirlpool Dryers
Kenmore 62602 Electric Dryer Logo
60 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
