Question about Hoover Vacuums
Which way does the final filter go in? Green side facing in or out? Thanks, Klair
    Novelist:
  • 97 Answers
Generally the green side faces out. In all honesty, it doesn't really matter, since the only thing that exhaust filter is really filtering is carbon dust off of the motor, and stuff that leaked through the other filters and already went through the motor, and it's not airtight so most debris just goes around it and into the air anyway.
-R
Posted on Aug 13, 2008
I just need to know whether the filter is installed with the black side outward or inward facing.
The coarsest side of the filter should be facing the dirty side of the airstream. The dirt / air should pass through the coarse side of the filter before exiting the finer side of the filter.
Hope that helps.
Mar 05, 2011 | Vacuums
How do I locate and find each of the filters?
The foam & filter assembly is behind the clear door with the latch you pull up on, located above the dirt cup. The hepa filter is on the right side of vacuum as you are facing it from front.
Sep 04, 2010 | Eureka 5892AVZ Bagless Upright Cyclonic...
HEPA FILTER REMOVAL
the filter should be easily accessable on the right side of the vacum cleaner if it's facing you. at the base of the vacum there is a large round cover that is removable and behind it it the filter. generally you dont need to replace it. its a big round spunge that you could rinse with water and squeeze out until it's clean. you also need to rinse the filter cover which is like a plastic netting. let it dry for 24 hours and you should be good to go!
enjoy!
Aug 10, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Which side should face me (black or white) when I put in the CF-1 replacement filter?
The white side is filter media and the black side charcoal. The black side should be the side that the air flows out of and the white the side that the air flows into.
Jul 18, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Vaccum cleaner not picking up (116.36933/Aspiradora)
Joan,
I had a similar problem with my upright and just resolved it today. Mine was also picking up with the beater bar, but not as good as it should and it had very little suction at the hose.
I did everything it said to do in my owners manual...
I looked into every entry to the dirt cup.
I checked for blockages into the bottom of the vacuum.
I cleaned the HEPA and regular filters and dirt cup - still no success.
I made sure the belt was working properly.
I finally sat and looked at how things should get into the clear dirt cup (bagless model).
I finally realized it had to be a blockage in the hose.
I completely detached the hose from the vacuum - this took some muscle.
Took the hose outside and used my high pressure nozzle on my garden hose to spray out the hose. It took a few seconds before a pretty large & stiff piece of paper (2"x2") and much more very dirty stuff finally blew out...
No wonder the vacuum had no suction!!!
The paper that was blocking the hose reminds me of a piece found under a Reese's Peanut Butter Cup! YIKES, it was probably candy causing yet more problems besides the extra pounds!!!
Hope this helps - I'm not an expert, just a frustrated cleaning fanatic who hates it when mechanical things don't work right!
Good LUCK!
rtwospeed in Henderson, NV
May 27, 2009 | Kenmore Vacuums
Which way does the final filter for the hoover u6430-900 go back?
It doesn't matter which way it goes but I recommend replacing it rather than cleaning it.
Aug 13, 2017 | Hoover Ultra U6430-900 WindTunnel Bagged...
Final Filter-Hoover U5399-900 WindTunnel Lite Upright Vacuum
Hi you could try these people who deal with hoover parts their number is 0845 230 6 230
they are called www.espares.co.uk
hope this helps if they dont have your part they should be able to get one or direct you to another supplier.
May 18, 2009 | Hoover U5399-900 WindTunnel Lite Upright...
Filter Queen motor brushes sparking??
SPARKING IS NORMAL,THIS IS WHERE THE BRUSH RESTS ON THE ARMATURE.IF YOUR STILL CONCERNED YOU CAN TAKE IT APART & CHECK THE BRUSHES(.250 OF AN INCH & UNDER THEY NEED TO BE REPLACED)IF ITS NOT MAKING ANY ABNORMAL SOUNDS AT THIS TIME I;D LEAVE IT ALONE.HOPE THIS HELPS.
Nov 08, 2008 | Filter Queen Cheetah II Ash - MU305...
Vacuums Logo
136 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
