Question about HP Pavilion dv6000z Notebook
Sudden power shut down/will not power up
MY HP dv6000z is about 1 1/2 years old. It has worked just fine but it lost power, just like someone pulled the plug, and now it will not power up at all. The blue light by the power jack is on but that is the only indicator light that is on.
I was starting to plug my Garmin in the USB port but it shut down before I could get it in, I don't think I even touched the port at all.
I have not noticed any clock problems but I did notice a strange time stamp on an IM I sent a few days back.
    Problem Solver:
  • 7 Answers
You can purchase cheap motherboards on ebay, here is a LINK for that.
Posted on Aug 21, 2008
  • 186 Answers
Try these steps :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If the Notebook doesnot start fine, we may have to need a Desktop monitor to check whether the issue is with the LCD, Graphic Card or the Motherboard itself.
Connect a Desktop Monitor to the VGA Port of the Notebook and press FN + F4 key to get the display on the Desktop monitor after the power button is pressed.
If you get the display on the Desktop monitor, the issue is with the LCD of the Notebook.
If there is no display either on the LCD or the Desktop monitor connected, the issue can be either with the Graphic Card or with the Motherboard itself.
Confirm if the Notebook is in warranty or not.
There are some known issues with few HP Pavilioin Notebooks installed with AMD Processors.
Try the link below and contact HP Chat Support if the Notebook is purchased in US to get it repaired for free :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01087277&dlc=en
Check the Product Number if it is listed among the once listed in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=c01300427#c01300427_
You can get the Notebook repaired for free if it listed among these numbers and is purchased from US.
Hope this helps...
Posted on Aug 13, 2008
Sudden shutdown
If the battery is full and still shuts down suddenly then it could be a heatsinking problem on your Notebook. Also try unchecking the option "Automatically Restart" from StartUp & Recovery section in System Properties.
May 03, 2010 | HP Pavilion dv6000z Notebook
Hp laptop is not shutting down after i shut down
we need to change the power options from control pannel and change the sleep options to never and then restart the laptop
its going to work
Dec 15, 2009 | HP Pavilion dv6000z Notebook
PC suddenly lost power will not restart
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 05, 2009 | HP Compaq nx9010
Not detecting my network anymore
Make sure the switch for the wirelless card is on.
Dec 03, 2009 | HP Pavilion dv6000z Notebook
My HP Pavillion dv6000 shuts down with battery in, runs on power no problem for quite sometime; w/batter it shuts down. Is it the battery? I called HP and they said I would have to bring it in for...
when battery is in if laptop shows charging (charging light blinking on laptop) then battery is faulty.
but charging not shows properly then motherboard is faulty.
Jul 16, 2009 | HP Pavilion dv6000z Notebook
HP L2000 Sudden shutdown wont power up power supply good
what makes you think the ac park is ok
19vdc measured with a voltmeter proves this , only.
a 2005 (as old as) Laptop
its not new, things this old do fail.
Laptops are like dog years.. 7:1. so yours is 84years old
to fix a desktop is super easy
to test a laptop takes greater skills, the take down. is tricky
we take out the battery,
the the pack just make the fan run in the PC
does it>? if not the pack is bad.
or the MOBO regs are shut down. (shorts on any thing inside
some times the 19vdc is ok, at that pack
then 1 inches inside the PC its dead due to that silly power jack loves to fail. but not taking the thing down and testing that
its all just a guessing game...
the only insight there is on electronics, is power first.
no power, no joy.
test the power feeds first.
Jul 17, 2017 | HP Special Edition L2000 LiveStrong Mobile...
Won't boot up, Hard drive self test result #1-07 Fail
Hi there.
The hard drive has failed and you will need to replace it.
If the laptop is under a year old take advantage of the warranty and send it in to be repaired for free.
Good luck and thanks for using FixYa!!
Apr 06, 2009 | HP Compaq Presario V2000 Notebook
No DC Power To Laptop
The problem is the input power socket on the laptop. It is either damaged, or the soldered connections on the connector has disconnected from the motherboard (eg formed a dryjoint).
It should not be too expensive to repair, or you can pull apart the laptop yourself and resolder the power connections. I suggest you use a temperature controlled soldering iron and ground yourself with a static strap for this repair.
Jan 07, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
