Televison & Video Logo
Dave Fry Posted on Aug 13, 2008
Instruction manual Required for a Digihome PVR80 TV receiver with twin tuner
  • Dave Fry Aug 15, 2008
    Thanks just what I wanted
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
929
Points
We have a 42inch 3d led digihome tv but we cant get the 3d to work what are we doing wrong
Can you please check the operation manual and the conditions mentioned in input for view in 3D, and check whether these are met?
Digihome 32845 lcd user manual
I need an instruction manual for a Digihome 32845 lcd tv
4helpful
Need the Digihome PVR80 manual or GUSTB250IV pdf manual please..
As far as I have checked your Digihome PVR80 is the same model as the "Goodmans PVR80".
the Goodmans manual can be downloaded from their website as given below...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
http://www.goodmans.co.uk/content/ug...language=en-GB
1helpful
How to tune freeview for digihome PVR80 it wont record bbc how to fine tune it .when we had to re-tune for channel 5 it worked perfect so please tell me how to do that again
On your remote control, press 'menu'.
Then select 'set up' on the screen.
Then select 'Installation' on the screen.
Then select 'Automatic channel scan' on the screen.
The box should then scan for all channels, and with luck BBC will be included. If not, please repost. Some older Digihome PVR80s can't cope with the new multiplexing standard employed by digital freeview.
I have a Digihome DV940B freeview receiver, and wish to set it up with a tv and video how and where do I put the areal and scart leads
This depends on how you want to use your kit, and how many scart plugs you have in your TV and VCR.
If you have 2 scarts in your tv;
Aerial coax goes to digihome aerial in. Aerial out from digihome to aerial in of vcr. Tune vcr into Digihome.
Scart plug from digihome to tv.
Scart plug from vcr to tv.
You can then record what you have selected on your digihome box.
In my humble opinion, it's worth splashing out on a pvr; you have more functionality such as being able to record 1 program and watch another.
Regards
Zahc
4helpful
Digihome pvr80 will not switch on
The digihome pvr80 can suffer from capacitors breaking down. If you have checked the fuse, and your not getting any lights or display, then it is possible that your power board has gone south. Unplug it, open up the box and look for bulging capacitors(warning, power is stored in capacitors-one of which is rated at 400v). If you're not happy fiddling with electronics, I'm afraid it's got to be looked at by a tech.
7helpful
4answers
Eurovox code
The new code for 5A01 from the 6th October is :-
KEY 00 = C2 B5 BE 41 0D 9B C5 7C KEY 01 = 6D EA 8E 97 6A AA DA 71
Please dont forget to leave your nice feedback. Thanks
5helpful
User manual digihome dtr80
There are two versions of the digihome dtr80 which are made by Vestel. If you look underneath at the product sticker you will find one of three numbers:
T810 : In this case youve been conned into buying a digihome pvr80. This has very limited functions and cannot series link.
T816 : This does support series link but you need to install new firmware using a computer a a serial extension cable. You can get the firmware from here: http://www.futaura.co.uk/vestel.html You want version 6.8. Bear in mind there areside affects to this program such as recording every episode that comes along on that channel and a very sluggish interface.
T825 : This does support series link by default. You go to the epg, highlight the program you want to record, Press the OK button and a menu will appear. Select series link.
Please be aware series link only stays active for 13 weeks so you will have to redo it halfway though a series.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
