Question about Kenmore 63793 Convection / Microwave Oven
Microwave oven Maybe more info will help find a solution. The microwave was ran without contents. After approx 15 minutes my wife realized what happened and shut it off. She said the unit was very hot to the touch. Approximately a minute later there was no power to the unit. Any other ideas on what may have been damaged? As far as the fuse solution goes, why does a qualified repair man need to replace it? I'm currently holding the only fuse I could find in the unit. Is there another fuse I'm not seeing that takes special skills to deal with?  Let me know, thanks Tom
  • Kenmore Master
  • 9,174 Answers
Due to running empty, the magnetron has overheated and the thermal cutout also called a (TCO or thermal fuse) or thermostat (if so equipped) on the magnetron has blown.
After 15 minutes of such stress, I would suspect the magnetron is gone, too, unless the thermostat / TCO stopped it in time.
Cross your fingers...
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find exploded views and order parts by entering your full model number at the Sears parts site.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Aug 18, 2008
SOURCE:
Our LG over the stove microwave oven LMHM2017ST is powerless.
Probably burned up the magnetron. You are cautioned not to operate the oven empty.
Jul 27, 2017 | LG Microwave Ovens
How can i evaluate what needs to be replaced?
No Aluminium Foil in microwave ovens!
Apart from damaging the magnetron by reflecting microwave energy back, it has the opposite effect by shielding the potato from the microwave energy.
Disconnect the power for 10 minutes. Try it again with a glass bowl of water. If it still doesn't work, you need professional service. You can't work on them yourself as they are so dangerous.
Jan 21, 2018 | Microwave Ovens
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Kenmore 401.8008700 ran 10 minutes thought I'd set on timer
It could be the fuse. You will also need to check the condition and alignment of the door switches.
Eric
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
Oven operating while empty
Yes, as long as you don't smell any burning, but as always, no microwave should ever run unattended.
Jun 03, 2009 | Microwave Ovens
The microwave was accidentally used without the glass turntable
It mkay just be the overload fuse inside the back panel. I highly recommend a certified electrician or repairman to change this. Good luck
May 11, 2017 | Microwave Ovens
Maytag microwave MMV5165AAB approx. 3 yrs old; everything works
maybe thers something wrong on its heater....go to electronic shop for more info. thanksss
Jan 21, 2009 | Maytag MMV5000 Microwave Oven
Operated Microwave with no food in it
Sounds like she blew the cavity thermal overload. you would have to take the cover off of it to find it. let me know if you need more assistance
Dec 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
wsw
Oct 09, 2008 | GE JVM1640 Microwave Oven
Kenmore 63793 Convection / Microwave Oven Logo
102 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
