Question about Toshiba Satellite A45-S250 Notebook
Toshiba M55-S1001 When I turn the power just hear 4 beep then nothing, the hard drive not run and no screen.
    Scholar:
  • 94 Answers
4 Beeps means there is a fault with the CPU.
It could be that the fan is faulty and needs replacing, or it coul be that the CPU is dead.
Unless you are technically mined enough to take the machine apart yourself, then your only course of action is to take it to a dealer for repair.
Posted on Aug 13, 2008
Black screen, hard drive not running
If you remove the power adapter, battery, RAM and hard drive. Plug in the power adapter and power it up. If you get a screen with error information on it, the motherboard is probably OK, if nothing there is a motherboard issue. If you get a screen remove the power, insert the RAM and power up again. Do the same after adding the hard drive.
Jan 03, 2014 | Toshiba Computers & Internet
How to reset toshiba satellite m55 s1001 without disc
You need the recovery disks one for Windows and one for the device drivers.
This WEB site can provide the recovery disks.
http://recovery-disks.com/toshiba/toshiba-satellite-m55-s1001.html
Aug 26, 2011 | Toshiba Computers & Internet
I HAVE A SATELLITE M55 S1001 WHEN I TURN IT ONI CAN HEAR EVERY THING STARTING UP SUCH AS WINDOWS BUT MY SCREEN ISNT TURNING ON
if you have windows vista or 7... press F8 simultaneously and see if your computer has the option where says "Repair My computer" select it and press enter.
follow all the process until get to the opcion where says " Repair your computer"
and then click " start up Repair" it that does not work try to Do a system restore"
check image to see how it looks like
if you dont see Repair my computer After you press F8 you will need the windows Recovery disc to do this process.
hope this help
Jan 31, 2011 | Toshiba Satellite Pro L300 Notebook
I have a toshiba satellite m55-s3314 and when I turn it on it stays stuck on the first screen and the laptop makes noises like it stuck
if it's making a clicking noise, like metal-to-metal clicking, then most probably your hard drive is failing. If this is the case, get the hard drive into a USB tray and get all your important data out of it. You'll have to get a new IDE/ATA hard drive for your Toshiba if you want to continue using it.
Jan 19, 2011 | Toshiba Satellite M55-S3314 Laptop
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
How do i store a satellite m55- s1001 to factory settings without disk
to restore to the factory settings press F10 or F11 on startup and then follow the screen prompts you will get two options for recovery destructive and non destructive select the one according to your need destructive will delete your data.
Mar 20, 2010 | Toshiba Satellite M55-S139 Notebook
My toshiba M55 Satellite will not boot up. My
Take the hard drive out and see if anything comes up on the screen. If so, replace the hard drive.
Does the screen get any brighter when you turn on the laptop? If not, the lcd cable, or power inverter may have gone bad.
Did you have any blue screen of death errors, or any other kind of errors before the screen problem? If so, you may have bad memory. Do you hear any beeps?
Jan 14, 2010 | Toshiba Satellite M55-S3314 Laptop
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Toshiba Satellite M55-S325
Do you see any of the power indicators on the laptop? Do you hear the hard drive churning at all? If none of the above, is your power supply okay? Your batteries charged?
Give us some more information and perhaps we can help further.
Mike
Jan 01, 2008 | Computers & Internet
Toshiba Satellite A45-S250 Notebook Logo
245 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
