Question about Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television
Double image i have a panasonic pt53wx53g it has double images how do i fix
  • Panasonic Master
  • 8,617 Answers
You need to replace both convergence ICs they are both STK392-110 you can get replacment Ics at the following link with free step by step instructions with pictures. here is the link.
http://servicemanuals.vstore.ca/
Posted on Aug 14, 2008
Panasonic pt-47wx53, no power, 3 blinks
3 blinks is indicating that the convergence has a problem The PT53WX53G convergence repair kit from www.tvrepairworld.com is the correct kit for your model. The kit contains the ICs, Resistors and the CD with repair instructions.
Feb 17, 2011 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic pt 4743g that just shut off. I
Thats the error code for the convergence circuit shutting the set down The PT4743G uses the PT53WX53G convergence repair kit which is available from www.tvrepairworld.com the kit contains the parts and the CD with detailed repair instructions.
Nov 21, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Iturn my Panasonic projection tv onand it turns
Thats the error for convergence failure. You can get the PT53WX53G convergence repair kit at www.tvrepairworld.com the kit contains the parts and CD with instructions.
Oct 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
Sep 08, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt53wx53g wheres pico fuse
R7080 is mounted parallel with Transistor Q7060 (base-emitter) supplying +20 volts to STKs
R7086 is mounted parallel with Transistor Q7061 (base-emitter) supplying -20 volts to STKs
Feb 27, 2009 | Panasonic Televison & Video
Panasonic rear projection model #- PT53WX53G will not turn on.
Happened to me, relays, either 1 of 2 so I had both replaced, about $300.00 to fix.
Nov 16, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
circuitcity
www.interactiverepair.com
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT53wx53g Rear Projection TV screen cracked
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Oct 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television Logo
125 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
