Question about Dryers
Zanussi TC7103 condenser makes a loud whistling noise
My zanusssi condenser works fine but has suddenly started making a loud whistling noise almost to the level of a siren. Took all the washing out and turned it on again, still the same noise. Looked inside, nothing unusual. Any ideas?
SOURCE: Loud humming noise from subwoofer
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
Posted on Jan 27, 2007
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
  • 11 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
SOURCE: My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Posted on Mar 19, 2009
pumpkinman
  • 1147 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
Whistling noise
I don't think your whistling is related to your chain adjustment. What else might be whistling ... helmet ... ???Did you change anything else? Was your chain loud before and possibly covered the noise you are now hearing?
Jul 21, 2013 | Honda Motorcycles
The motor by the freezer runs loud
What is the model number of your unit?
Nov 27, 2012 | Hotpoint Refrigerators
My Dyson 07 still seems to be working fine but it just started making a loud whistling noise. I looked for any air leaks but cannot locate any. The whistling noice is quite loud and annoying. Are we doing...
Sorry to hear you're having difficulties with your DC07. If you've been unable to locate the source of the whistling noise, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 21, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The drum of my Zanussi TC7103 was making a knocking noise and has now also stopped spinning i have removed the side and the drive belt is fine. The belt loops the drum and then goes round a black plastic...
yes you can replace the belt tentioner . disconnect capacitor wires remove the spring off the motor slip the belt behind the pulley so the motor can move round. remove the rear fan cover ( screw and retaining clips) this to allow pulley to be slid off. fit new tentioner pulley and pull belt in front of pulley refit spring to motor down to cabinet.reconnect capacitor. refit fan cover.125 01 25-20/8 is part no for one of 12 variations of this model use the product no to get the right part 916xxxxxx
Aug 26, 2010 | Zanussi Dryers
The drum for our Zanussi TC7103 has stopped spinning
sounds like a new drive belt is required. pull the machine out remove the mains supply!!!!
remove the top and look into the back of the machineif you cant see the belt them remove the back of the machine, it's like a small fan felt from a car it's either come off or disintegrated in which case you'll need a new one.
Nov 09, 2009 | Dryers
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Loud whistling noise coming from tv speakers
a couple of things could make the tv chassis whistle
1 coud be dry solder joint probably on power capacitors
2 IF your tv has tube the board on the back could be making the noise its to do with the yoke on the way out!
Jul 13, 2009 | Televison & Video
Suddenly making loud static noise
I have a dect 6.0 cordless phone and all of a sudden it started making this very loud, high pitched continuous whisltling sound. It only stopped when I took the batteries out. After putting them in the phone seems fine now.
Any ideas what happened?
Jun 28, 2009 | Uniden Cordless Phone
Loud whistle noise
Check your power steering fluid reservoir.
Mar 07, 2009 | 2000 Land Rover Range Rover
Whistling noise
Sounds as if it needs descaling. Do you live in a hard water area?
Aug 09, 2008 | Cuisinart CJK-17BC Cordless Electric...
Dryers Logo
Top Dryers Experts
