Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Trouble code: Standby LED blinks 9 times
I have a sony wide screen projection tv model # KP51WS520. After recently rearranging our living room; we moved the tv to the oppisite side of the room, the tv doeen't come on. Instead the standby LED just continueously blinks 9 times then pauses for about 3 seconds and then another 9 blinks. If you continue to try to get it to come on it eventually will turn on and everything works just fine. Somtimes it takes 5or more minutes of pressing the remote to get it to come on. My tv, which is the same model & also about 3 years old, is doing the same thing. The stand by light blinks 9 times. I punched in the code to get the tv in diagnostic mode and it came on and showed all zeros except #9 and it showed #104. If you could give me any help I would greatly appreciate it.
  • ffrandy Aug 15, 2008
    Is this g board a unplug and plug item that I might be able to replace or would I have to take it to a shop for repairs?
  • 2,336 Answers
If I may add to Bestdarngood post that the 9 blinks means:
+/- 19V line is shorted
IC708 could be defective
PS701 or PS702 is opened.
To do this repair you will need to have basic electronics knowledge that includes hand soldering, use of a DVM and be very careful when working around high voltages.
Let me know if you require further assistance.
Posted on Aug 13, 2008
  • 3,037 Answers
You will need to replace the G board on this tv to fix the problem
  • Benjamin Patri
    Benjamin Patri Aug 16, 2008
    You will need basic knowledge of electronics as Jaime says from soldering to the use of a DVM. If you rate my solution as Thanks for Trying, you will see the exact parts that may be causing the problem posted by Jaime and he will be able to provide any further info into this as he is one of the best TV techs here.
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Trouble code: Standby LED blinks 9 times
Try pushing the buttons on the remote and let me know what comes up on the screen if anything.
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
Posted on Jan 13, 2008
Is it a problem of the inverter board ?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 12, 2016 | Sony 40 KDL40BX420 LCD TV
Sony 3lcd wega engine tv screen turns black, power/standby button blinks 45 times, then screen goes back on. This repeats over and over again. Do you know what's wrong with my tv? Thanks.
First check your tv if it has standby power. if it has standby power please do count the number of blinks of red led. (it is on a sequence) so that we can walk through the steps and procedure to get rid of the trouble. if theres no stanby power, its probably the power supply. please do check busted fuse and replace with same ratings.
Apr 16, 2013 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony Trintron's LED Light blinks 9 times when I try to turn on the set
  1. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative). If you wish to get more details about the blinking codes to Sony brand TVs, check this link. Pull up older posts there.
Mar 04, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony 52" rear projection tv red light
I will need the model number to assist if its the KP51WS520 the 9 blinks is zero cross diodes on the g board.
Aug 02, 2011 | Sony Televison & Video
Standby LED blinks 9 times; TV does not come on
An easy problem for a Sony authorized service center anybody else they may not have a clue.
Mar 27, 2009 | Sony KV-36FS16 36" TV
Sony KP51ws520
9 times blink shows Audio Error in your TV.
Let me know if you want to fix it by yourself.
Feb 21, 2009 | Sony KP-51WS500 51" Rear Projection...
TV won't turn on
There's a small diode on the power supply board that causes this. Its identifiable by its purple stripe. You will need the correct type of diode to fix this properly. The diode supplies the standby voltage to the system control circuit, so when it fails, the TV will never come on.
michtech
Feb 12, 2009 | Sony KP-51WS520 51" Rear Projection...
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony Kp-fw46m31
count the flashes again carefully, as that model should only blink a maximum of 9 times, unless your getting two seperate codes. Try counting and trying to notice if it pauses a second before blinking again. then let me know what you discover.
Apr 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
codes.
Jan 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
310 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
