Question about Philips 60PP9352 60" Rear Projection Television
Picture burnt in on left side
Hitachi 53UDX10BA
the left side has image burnt in . it only appears to be that side , any easy fix or repair shop ?
  • 927 Answers
Good Day, azues;
If the CRT's are "burnt" then there no solution but to replace the 'tubes'. The cost would be very high if all three CRT's are "BURNT". You can determine yourself if you remove the screen and look into each 'tube'. Good Luck, big IRISH.
Posted on Aug 30, 2008
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I have a blue and yellow wave across the top of my tv its a hitachi 53udx10ba
Ur convergence it dead.U know how to solders?Must replaced 2 Convergence ICS and all it resistors.Tries Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Jan 17, 2010 | Hitachi 53UDX10B 53" Rear Projection...
The screen seems to have two of the same image, green and red.
Yes.
The fix is to replace the two Convergence IC's( STK392-110's) with STK392-150's. They are located to the right side of the chassis and mounted to large heat sinks. Be also on the look out for some burnt resisters and or discolored resistors that failed becuase of the IC's failing. These would be located just to the left of the heat sinks. If they are burnt or severly discolored, you will need to replace them with the exact valued resistors. In this high current circuit it is a must.
I hope this helps,
Skyassoc
Jan 07, 2010 | Hitachi 60FX32B 60" Rear Projection...
The pictureshave shades of greenish-yellowish
It sounds like you have a convergence problem; there are 2 STK-392-110 IC'S THAT NEED TO BE REPLACED; sometimes there is a resistor or two damaged by them; Cost depends on if you can do this repair yourself---parts cost less then 20 dollars on Ebay---most shops will do this repair for about 300 dollars---keep in mind this is the slow time of year for TV repair shops---i have fixed dozens of hitachi's (43uwx10b etc) for about 200 parts and labor--its a easy set to do this repair on and takes about a hour.----shop around in your area---200 is less then a new set will cost you and this is about the only problem these sets ever have.
if this has been helpful give me a vote here; I do this for free. ALSO: IF YOU HAVE MORE QUESTIONS OR NEED DIRECT ASSISTANCE:
etower.766@netzero.net
I like the HItachi sets---I OWN TWO OF THEM.
Aug 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Jul 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Color problems with Hitachi Ultravision 53UDX10BA rear projection television
Blue color has shifted. two months ago it had shifted slightly. Now it has shifted more. All three bulbs are working. Please suggest a solution.
Jul 08, 2008 | Televison & Video
Hitachi tv
the 53udx10b was changed in production - the change was to the lenses on the picture tubes all else in the set remained the same
thanks
scott
Jun 13, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi Mo# 53uwx10ba double image
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Dec 03, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Swoop of red coming down from left
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 05, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
