Question about Frigidaire Dryers
Frigidaire dryer, still no heat after replacing element and checking the thermal limiters.
  • 770 Answers
Have you checked the incoming power for 230 volts ?? the unit will run only on 1 leg but needs both (230v) to heat
Posted on Aug 13, 2008
My dryer suddenly stopped drying today. It just blows cold air. Before I took notice of all the lint in dryer, I took the heating element coil out which doesn't look damaged.
The lint MAY have caused a thermal limit fuse to blow out. If that is the case then it has to be replaced. There is also a chance that the heater element has failed and as you saw it is like a light bulb coil. You need to inspect it very closely if you don't have an ohm meter to test it for continuity. Frigidaire 131553900 Heating Element Assembly PartSelect
and
Frigidaire 134120900 Thermal Limiter Limit 220 PartSelect
Dec 18, 2017 | Frigidaire Dryers
Clothes dryer blows thermal limiter. Replaced and worked perfect for three days, then blew again.
I appreciate your post, David!
Based off the information you have provided your Frigidaire dryer is blowing the thermal limiter and you think the problem could be with the motor or heating element. In order to pinpoint the problem with your dryer I would suggest seeking assistance from a professional technician. They will have the appropriate tools needed for test each component and this will help prevent you from purchasing unnecessary parts. I hope this information is helpful. -Matt
May 28, 2015 | Frigidaire Dryers
Dryer not heating
Thank you for your inquiry, friend!
Based off the information you have provided your Frigidaire dryer is not heating. This could be a potential issue with your heating element, timer, or thermostat. In order to accurately check each part you would need to disassemble your dryer and test each piece for the proper continuity. This is not a simple DIY job and I would highly suggest contacting a professional technician comes out for proper diagnosis and repair. Best of luck! -Matt
Apr 20, 2015 | Frigidaire Dryers
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Dryer quit heating no power to element what is wrong?
The problem is most likely the thermal cut-off and the high-limit thermostat. The thermal cut-off blows when the high-limit thermostat fails and since these parts are wired in series with the heating element, power to the heating element is therefore terminated. Check the continuity of the thermal cut-off and if it reads open, replace it along with the high-limit thermostat.
You can bypass the thermal cut-off and the high-limit thermostat for troubleshooting purposes. Join together the wires of each part and insulate it properly then reconnect power. The two components indeed need to be replaced if the dryer heats up. If not and still no power to the heating element, check the continuity of the heating circuit. Check the continuity/resistance of the heating element if there's power to its terminals but doesn't heat. Replace the heating element if it reads open.
Let us know if you need further advice. Just indicate the exact model number of the dryer for accurate troubleshooting tips.
Jan 23, 2011 | Kenmore 700 6972 Dryer
Replaced thermistor & thermal limiter still no heat on an affinity 7000eg series dryter
check the element,then the thermal fuse on the dryer vent housing by the exhaust outlet on the rear or on the blower housing on the dryer
May 05, 2010 | Frigidaire FEQ1442ES Electric Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Frig. model# gler642as3.. No power. No light.
Go to http://www.partselect.com/ModelFrames.aspx?ModelID=1107121&ModelNum=GLER642AS3&mfgModelNum=&ManufactureID=4&Selected=ZGBPCQG3&Position=4&mfg=Frigidaire&Type=&Mark=0 the parts you need to check are F15, F33 and F36. F15 is the element. F33 is the High limit thermostat and the F36 is thermal limiter. The most common problem with these dryers when they are not heating is a bad thermal limiter (F36) F33 would be my second guess and the element would be my next. Either one of these could be causing it not to heat. Good luck
Dec 15, 2009 | Frigidaire GLER642A Electric Dryer
My dryer run but i get no heat
I replaced the thermister and it solved the problem
Jul 21, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
100 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
