Edimax Fast Ethernet PCI Adapter card 100tx-Di
I fitted the above to an old ish IBM computer. It came with a floppy for the driver. The computer doesnt recognise the hardware and the floppy will not run. I have downloaded its content to the harddrive but it still wont run it. Is the computer to old maybe ?
  • 781 Answers
Probably as south bridge and north bridge couls be to old to recognize it
Posted on Aug 13, 2008
Need drivers for ibm 10/100/1000mbps gigabit ethernet low profile pci express adapter Item#53y4005-co
This card is equivalent to the
Marvell Yukon 88E8075 PCI-E Gigabit Ethernet Controller
This should be the correct driver:
Follow the instructions at the site.
Apr 11, 2011 | IBM 10/100/1000Mbps Gigabit Ethernet Low...
I have a Dell XPS400 and can not connect to the internet because the machine does not have any installed network adapters. I have always had internet access...where do I find this adapter if I can't get...
This is onr example of a Network adapter, or also know as an Ethernet Adapter Card,
This is Dell Support >XPS 400 desktop computer > Service Manual,
1) Work on a table. Computer off, and unplugged from power, open the computer case.
(Removing the Computer Cover, in the list)
2) Follow Anti-Static precautions.
[Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the delicate hardware components, inside a computer.
To relieve your body of Static, TOUCH the metal frame of the open computer case.
Should you leave your computer in the middle of working on it, upon your return be sure to Touch the metal frame again ]
3) View the motherboard inside your computer.
(The motherboard is also referred to as the Mainboard, {Proper speak}, and System Board)
Technical Overview > System Board Components,
Viewing the illustration of the motherboard, the Ethernet Adapter Card example I gave above, would go in either one of the PCI expansion slots.
These are white in color, and in the illustration are labeled - PCI Card Connectors.
If there is already an adapter card installed in both PCI expansion slots, then see if the PCI Express x1 expansion slot is open.
In reality, PCI Express is a better technology than PCI.
Shown on the motherboard as PCI Express x1 Card Connector.
This is an example of an Ethernet Card, (Ethernet Adapter Card), that uses the PCI Express x1 expansion slot,
The reason I have suggested buying, and installing an Ethernet Adapter Card is threefold.
1) You may have your Ethernet cable plugged into the Ethernet port of the computer,
[Number 3 - Network Connector],
and the built-in Ethernet is no good.
Reinstalling drivers May help, but the above is a sure thing.
2) You have an Ethernet Adapter Card plugged into one of the PCI slots, or the PCI Express x1 slot, and the Ethernet adapter card is no good.
They do go bad, and are economical to replace.
3) There was an Ethernet Adapter Card installed previously, but taken out before you received the computer.
Jul 02, 2010 | Dell XPS 400 PC Desktop
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
Network card cnet pci-bus adapter without drivers for linux pleas
Install the drivers that came with it. it's usually comes witha CD. If not, download the drivers from cnet website. After you install the drivers turn off your computer, open the cover of your CPU and plug the adapter on any available PCI slot. When your restart your computer the card will be detected and drivers will b e installed automatically.
Jun 08, 2009 | Cnet : 10/100 PCI FAST Ethernet Card...
Compaq Fast NC3121 Ethernet PCI 10/100 WOL Adapter drivers
go to
you should be able to get your drivers from there and its free to join.
Mar 12, 2009 | Computers & Internet
If it is a laptop or a brand PC, just post a new request on Fixya with computer's make and model, for explample Dell optiplex 120, we will find the drivers for you.
Ifcomputer is assembled you will need to access the motherboard, and the audio card and posthere the code number printed on the motherboard, on on a sticker on top of the motherboard, and post also numbers you find on all device cards (PCI, AGP etc.).
Here is how board identification numbers look like
See also:
Motherboard Identification
How to Find Out Your Motherboard Manufacturer and Model
Sep 13, 2008 | Creative Labs Sound Blaster Live! 5.1...
Corrupted network drivers
what OS are you running,
Try removing it and reinstall
if it persists then try another card
update drivers and this should fix the problem
another thing also worth thinking about....
Maybe time to consider formatting the system and reloading it again with a fresh install.
Aug 02, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
