Installation of a mini pci card for a toshiba satellite 1405-S171
I need to know how to physically install the mini pci card I bought to be able to use wifi on this laptop. Can you help?
  • Amydhv Aug 13, 2008
    It's old, a toshiba satellite 1405-S171 laptop, and the card was described as an Toshiba Satellite 1400 Series Mini-PCI Laptop 802.11b/g Wireless Card. I'm not sure if that's helpful. Thanks either way!
  • Amydhv Aug 14, 2008
    You are awesome! That was exactly the instructions I needed! It took me a little while to slide the card in correctly - I was worried about damaging it. But once I got it in, no problems. I'm up and running. Thank you so much!!
    Genius:
  • 2,028 Answers
What model Toshiba do you have, and what is the make and model of the card?
Posted on Aug 13, 2008
  • Ryan Rogers
    Ryan Rogers Aug 13, 2008
    This machine isn't that old, and it's still a good machine. The wireless card slot is located on the bottom. With the machine upside down, battery towards you, it looks like there are three covers on the bottom to the left of the battery. The closest to you is the hard drive, the next is the memory, and the cover furthest from you is the wireless card slot. Under the cover you should see two wires, one black, one white with connectors on the end. Slide the card into the slot, and connect the wires. If you're not sure which wire goes where, don't worry about it, they will only go one way. If they are on incorrectly, you won't get a good signal. Keep in mind that you need the wireless drivers in order for the card to work. If you don't have them, you can find them at Toshiba's support site. If you have any problems get back to me, and I'll see if I can work you through them.
  • Ryan Rogers
    Ryan Rogers Aug 14, 2008
    No prob, anytime, if you have anymore questions feel free to ask, and don't forget to refer Fixya if you know somebody that has a problem.
Reset Satellite 1800-S207 to factory settings
its in the manual, lost it?
if yes, go to their web page, and read it there.
Toshiba , dot , com.
always there, and ready.
Oct 01, 2013 | System Integration Business Brand 160GB...
Need drivers for wireless mini lan card for Toshiba Satellite 1900-704
http://www.downloadatoz.com/driver/download_124691,toshiba-satellite-m35x-s3491-intel-802-11b-g-mini-pci-wifi-driver-8-0-12-9000w2.html
copy this url and paste it in your browser and lunch.the download button for your driver will appear for your download.install/run setup.exe after ward and your problem would be fixed.
rate this solution please
Nov 24, 2010 | Intel Toshiba Satellite Mini-PCI Laptop...
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
Toshiba Satellite 1405-S171 dead screen; external monitor works fine. How do I open case to check video cable connection?
Unless your screen's hinges (pivots) are busted, the video cable ain't gonna come loose on its own.
But if you have to check, it's underneath the keyboard. Remove the plastic strip above the KB, after that, it's three screws (L, middle, R), and you can lift up the keyboard. The video cable is the big bundle right behind the DVD drive.
Mar 12, 2010 | Toshiba Satellite 1405-S151 Notebook
How to remove the intel3945abg wireless mini-pci-e card of toshiba satellite u205
Mini pci-e cards can be removed by clicking the card towards the case. The card will then pop out so you can remove it.
Jul 06, 2009 | Toshiba Satellite U205 Notebook
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
Mar 19, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
If you flip it over, you will see three slot covers going from left to right: the disk drive, memory, and wireless card slot covers.
  1. Get a flat head screwdriver and remove the slot cover.
  2. Disconnect the black and white antenna cables from the card
  3. Push the latches outward to release the card.
If you need further help, get the disassembly manual.
Jan 13, 2009 | Computers & Internet
Mini pci wifi for toshiba 1405 s-171 laptop winxp
As long as you have an open minipci slot, they should work. The antenna pigtails should plug into the card as well.
Oct 02, 2008 | Toshiba Satellite 1405-S151 Notebook
Graphics problem dear sir i have a problem in my laptop.plz solve my problem . i have a laptop toshiba satellite model no. 1405-s171. but graphics driver is not my laptop.so movies , games not properly...
Please note down your tag no. or model no. which series before you vist the Tosibha site for support you must know according to region wise there is change in product specification
Go to this site and select your region the go to product support download and input all the required information, you may find the exact driver for your laptop
http://www.toshiba.co.jp/worldwide/index.html
Jul 20, 2008 | Toshiba Satellite 1405-S151 Notebook
Computers & Internet Logo
459 people viewed this question
David Payne
David Payne
