Question about Marantz SR-4300 Receiver
Standby issue - overheating?
I have a Marantz sr4300 receiver which works perfectly but after about an hour it goes onto standby and you have to power on and off to fix - it then works perfectly again. Any idea how to fix this?
  • Scott Frye
    Scott Frye May 11, 2010
    Hi...
    Are the speakers the right ohms? ( impedance) and are they all really connected at both end?
    Is there good airflow all around the case?
    Thanks
5 Suggested Answers
SOURCE:
cyrylthewolf
  • 143 Answers
SOURCE: Problem with Marantz SR5500 Receiver
Sounds like you have an issue with your electrical circuit. Your receiver could be receiving spikes of current from the electrical wiring in your house.
Review your current electrical situation. Keep in mind that certain outlets are on the same circuit and that running multiple, high-wattage devices on the same circuit can cause issues with some of those devices. Especially when it comes to turning devices on and off.
Many devices take a sudden, rapid charge to power their circuitry the moment you turn the device on. Home audio and HVAC systems are particularly notorious for doing this. Other devices on the same circuit can sometimes suffer influxes of power flow and may either turn off or go into standby mode to protect themselves from the resulting surges.
I've lost audio systems that way... I lived in an apartment building that has wiring most likely dating back into the 40's. I once turned on a space heater on it's max 1500 watt setting and blew my Logitech Z-680 speakers. (The "BOOM" sound that emitted from my subwoofer was AMAZING. I had just blown an amp circuit. It literally exploded inside of the subwoofer. Took pics and everything.)
If you have the means to do so... You might consider re-wiring your electrical circuit. Take into consideration where you're going to run certain devices and wire the system accordingly.
In the meantime, you would want to be sure to buy a HIGH-QUALITY surge protector for the audio system. Spend a few bucks and get a GOOD one with a good warranty on it. Don't use those cheapy ones that we only really use to split the outlet. NOTHING under 1,000 joules.
My receiver sometimes locks itself like that, though. If we have a power outage or the unit is unplugged suddenly, it will keep itself in standby mode until you unplug it, press the power button a few times to discharge any current left in the capacitors and plug it back in normally. Only then will it turn on again.
Let me know what you come up with.
Cyryl
Posted on Nov 03, 2007
smarthome2
  • 1114 Answers
SOURCE: marantz SR8001fail to standby mode, will not reset
Test all your speaker impedances and check for shorts on both wiring and speakers. Use a digital multimeter. If you still have an issue, disconnect all speakers and test receiver. If you still have a problem, post a comment and I can help some more.
Posted on Aug 09, 2009
SOURCE: Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Posted on Nov 04, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a marantz sr5001
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 09, 2011
Marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Feb 26, 2012 | Marantz SR-5600 Receiver
I have a marantz sr5001 av receiver. I bought it in sept 2008. It was working perfectly till a week back when it went into standby mode . Usually by pressing the enter button it used to come back to...
Mar 09, 2011 | Marantz SR5001
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
Sr 4300 reciever will work for 10 mins or so then cuts out
It may be an overheating problem. Make sure it is well ventilated. Also it could have a build up of dust bunnies inside in some of the heatsinks. If you are comfortable with it, take of the cover and gently blow it out with a compressor (low PSI) or canned air so it is clean inside. May also be an intermittent part which is a bit harder to find.
Jul 01, 2010 | Marantz SR-4300 Receiver
Hello there Ed.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
Marantz SR8001fail to standby mode, will not reset
Aug 07, 2009 | Marantz SR8001
Sr4300 mainly dead
Hi..
If you dont mind getting a real good service manual , try
www.stereomanuals.com
I'd say 15-25 $
Jan 08, 2009 | Marantz SR-4300 Receiver
Center channel goes muffled after a while of use.
It is likely that something overheating is causing the problem, but nothing should be overheating. Cleaning won't hurt and may help but it is likely to require repair of the faulty component, perhaps a failing capacitor or amplifier.
Dec 29, 2008 | Marantz SR-19 Receiver
SR4300 Centre Channel
Hi...
Try another GOOD speaker on your centre channel.
If the buzz ....buzzes off, it's a bad speaker.
If not , It's in the power amp section on the unit.
Sep 14, 2007 | Marantz SR-4300 Receiver
Marantz SR-4300 Receiver Logo
97 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
