Question about Toshiba Satellite A105 Notebook
RC32 DirecTv remote
Jeff,
Where is the third screw in the battery compartment? I removed the cover and two screws at the bottom of the remote and cannot see another screw.
DM
  • 11 Answers
There is no third screw there. There are four more screws which are accessed by prying off the GREY panel on the front of the remote.
Six screws total. Take 'em all out and it comes apart.
Posted on Feb 05, 2009
  • 667 Answers
Hi DM - my mistake. I was thinking of another remote. So many remotes. I will post the correct fix on your original thread. Once you read it could you PLEASE rate both as fixed. Believe me, it's the right answer. I don't want to have an extra thread open for the same problem. Thanks.
Jeff
Posted on Aug 14, 2008
How do i clean the directv rc32rf remote control device?
remove 2 screws under the battery compartment but you should remove the battery first.. and remove the front cover design and you can find a hidden 4 screws. after removing those screws then you can clean the keypad by water with soap using used toothbrush.
Jul 06, 2014 | Directv New Original RC32RF Remote Control
The power button in my Gateway laptop MT6451 got pushed it can't be accessed from the top. How can it be accessed from the button?
Quite easily Sergio
The plastic Power On button you see, presses against a carbon button Power On switch, below it.
I suggest removing the Switch Cover, and then you can access the Power On switch's carbon button, and press it down to turn the laptop on.
You can also, then see about repairing the Power On button assembly, or replace the Switch Cover.
1) Remove ALL power. Remove the AC adapter {Charger}, and Battery.
2) Laptop closed, laid on it's top; Bottom side up.
Turn it so you are looking down in the Battery Compartment, where the Battery was......
Down in the Battery Compartment are 4 Philips head screws to remove. You need the smaller No.1 Philips screwdriver, or the equivalent Jewelers screwdriver.
Here is the Base Enclosure, (Bottom Cover), not installed on the laptop,
http://www.ebay.com/itm/39MA7BATA10-Gateway-MA3-MT6451-Bottom-Case-Cover-39MA7BATA10-Genuine-/321101430142?pt=LH_DefaultDomain_0&hash=item4ac322fd7e
There are 4 views. The page automatically opens, with a Bottom view, and the Battery Compartment at the top.
SET, your mouse cursor in the middle of the photo. This allows the Zoom In feature.
Go to the top where the Battery Compartment is, and view the 4 holes going along the Top.
This shows you where the 4 screws to be removed are.
Same design, different Gateway notebook,
http://www.insidemylaptop.com/remove-keyboard-from-gateway-mt6704-model-ma7/
Go to the third photo down. Has two screws circled in Red.
I just want you to look at the Battery Compartment. (Not the red circled screws)
Look under the whitish - www.InsideMyLaptop.com -
You can see the first two screws pretty visibly. Almost make out the 3rd one, no to the 4th screw.
Once these 4 screws are removed, turn the laptop over.
Open the laptop.
Now you are going to remove the Switch Cover.
In the above link scroll down to the 5th photo, and 6th photo.
This video also shows you,
http://www.youtube.com/watch?v=KjOVOLOW1Hc
From 0:45 to 0:47
Please use care when removing, it is plastic.
The video has been sped up.
This is a look at the Switch Cover removed,
http://www.ebay.com/itm/8015907R-Gateway-CENTER-COVER-MT6700-MT6451-MT6821-MT6828-MT6452-MT6705-GRADE-A-/321068043361?pt=US_Laptop_Housings_Touchpads&hash=item4ac1258c61
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 04, 2013 | Gateway MT6451 Notebook
How to remove dvd drive on aspire 5720
A) Remove the AC adapter (Charger) and Battery
B) Laptop closed turn it over, lay it down on a soft cloth on a table, Battery Bay Compartment AWAY from you.
C) The Thermal Cover is the largest cover on the bottom of the laptop. Goes from the right side to the middle, and very close to the Top and Bottom.
There are four Philips head screws to remove in the cover, before the cover can be removed.
1) Under the middle of the Battery Bay Compartment, and at the Top/Left corner of that rectangular vertical vent, in the Thermal Cover.
2) At the Bottom/Right corner of that vertical vent, in the Thermal Cover.
3) In-between the two horizontal vents, located at the Bottom of the Thermal Cover.
4) Straight above the screw removed in 3), is the last screw to remove. There is a round shaped vent, inside a square at the top right of the Thermal Cover. The screw to be removed is at this vent's Bottom/Left corner.
Once all the screws are removed, ease the Thermal Cover up from it's left side, (Middle of laptop), at an angle, then remove.
D) In the opening with the Thermal Cover removed, there is one Philips head screw to remove, then the ODD can be removed.
(Optical Disk Drive. The DVD drive)
This screw is located..............ack, ack,.......fzzzt.......ffffzzzt,......
Jun 02, 2012 | Acer Aspire 5720 Notebook
Sony vaio pdc-8x2l disassembly
The cover above the keyboard might be secured by screws inside the battery compartment. Just remove all the screws from the bottom of the laptop, but check inside the battery compartment, hard drive compartment, dvd drive compartment, memory compartment and wifi compartment for screws once you remove them or remove the cover.
May 09, 2012 | Computers & Internet
Disassemble DirecTV remote?
There are a total of SIX screws. You have already found two in the battery compartment. There are four more under the GREY panel on the front of the remote. That grey panel pries out; there are two tabs on the lower sides and one on the top, above the > button, that hold it in. Should not be hard to get it out to reveal the four screws. Take them all out, and the remove easily pries apart for service access.
Feb 05, 2009 | Directv RC23 Remote Control
Disassemble DirecTV RC32 remote to fix sticky buttons
Feb 05, 2009 | Directv RC32RFK Remote Control
Controler will not turn channels
If you still have the manual that came with remote, reprogram the remote for your receiver. The RC32 is has had some issues because of all the new Directv components available
Jan 05, 2009 | Directv RC32RFK Remote Control
Directv RC32 remote
Hey DM - Did you remove all 3 screws under the battery cover? The two little black ones near the bottom and the one up inside the battery compartment? Thanks.
Jeff
Aug 11, 2008 | Toshiba Satellite A105 Notebook
Directv remote
Assuming there are no visible screws on the back cover, look for screws in the battery compartment.
Feb 16, 2008 | Universal Remote Control DIRECTV Universal...
Toshiba Satellite A105 Notebook Logo
160 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
