Question about Acer Aspire 5100-5022 Notebook
No power up
Ive got a power up problem my laptop has no power ,checked the mains fuse and adapter but both fine any suggestions,battery has gone flat as it is not being charged by mains
  • butrflygirl8 Sep 24, 2008
    my computer will turn on for 3 secs the screen will go blue and it turns off
  • 129 Answers
Check the receiving pin on the laptop, it may be bust. If it is you will need a new board as you cannot purchase the charge pin seperatly, if it is ok, your charger is probably burnt out. You can buy a universal charger if you cant replace the original.
Posted on Sep 18, 2008
Unit will not turn on after power down for 3 days.
Assuming you are running on mains, remove battery and try without battery installed.
Try removing mains and battery power and press down on the power button for 30 secs then reconnect mains power and try again.
If this does not work and you know the Power adaptor to be working, I'd suggest its a main fuse in the laptop gone
Dec 29, 2010 | HP Pavilion dv6000z Notebook
My Asus eee pc 901a: i get no charge lights i get no power light even when the charger is pluged in. ive gone as far as unpluging bios battery and replaceing. any suggestions
Hi. This could be a power adapter problem. Try this troubleshooting first, if nothing happens then i suggest you purchase a new adapter. Take out the battery and unplugged the power adapter to the wall socket. Press and hold the power button for 30 secs. Put everything back in then turn ON the computer.
Sep 02, 2010 | Computers & Internet
Packard Bell Laptop goes flat even when plugged into the mains su
Are you sure that the power adaptor is working? Does it have any light on the adapter box that informs about it's operation?
What usually happens is that the cable going from the adapter to the laptop gets crackled from repetitive bending, either at the plug, or at the box inlet. Inspect if the cable is intact, and if possible, checks if there's a required DC voltage on the plug.
Perhaps you might need a new adapter for your laptop.
Dec 07, 2009 | Computers & Internet
Battery on packard bell
Probably not. Try removing the battery from the unit and just power-up from your adapter connected to the mains. See if the problem persists. If so, you may have another issue.
What, if anything, do you see on the screen as it is booting? This may be an indication of the source of the problem.
Nov 19, 2009 | Packard Bell Easy One Silver 2120 Notebook
Battery charging issue
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 11, 2009 | Advent Netbook
Black screen, power and battery are ok
Check fuse in plug first...!
Take the battery out and then plug the power adapter in and try to power it on, if it comes on power the laptop off again remove power adapter and put the battery back in and plug the power adapter back in.
If it didn't power on or light up on the laptop then the power adapter has gone faulty, buy a new one.
Power it on again, if it doesn't power up at all and there are no power lights the battery has come to end of its life.
If it powers on fine, then it just locked up, one of those things.
Aug 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Compaq laptop 6710b, wont turn on battery now gone flat ac adapter ok,no lights comes on no fan no hard drive whiring absolute dead suggestions please Thanks
I know batteries cost a little, but replace it. The power connection works through the battery charging unit. If the battery is no good, your connection is lost.
Jun 11, 2009 | Computers & Internet
No power. Adapter light flashes when connected to laptop
thanks for using fixya!!
Please do and observe the following:
1. Uninstall the battery pack.
2. Then, connect the AC adapter, we will try to use the power coming from the AC, then turn on your laptop.
3. Observe what will happen.
4. If still doesn't work, install again the battery, then connect the AC adapter, check if its going to work.
5. If not, perhaps you have a problem neither with the battery or the AC adapter.
I suggest that you bring your laptop to a service center. Good luck!
pls rate me positively! thanks!
Mar 30, 2009 | Acer Aspire 3680 Laptop
Amilo m 3438g laptop will not power up
I've found a few times that removing and then re-seating the battery can fix problems like this. You may want to give it a try.
The chances are minimal ,.. but it works sometimes.
There might also be a prob with your adapter. I have a Dell laptop and have had to
replace the adapter 2 times.
If it isnt that ,.. it will be the plug in for the adapter at the back of the computer that needs to be replaced.
Jan 15, 2009 | Computers & Internet
Was using my laptop working fine then message came up battery is low yet i had my laptop plugged into mains help my laptop went off checked fuse on plug still dose not work made sure all the points were...
Your laptop's power adapter must be the problem, try borrow a power adapter power cord similar voltage rating and connector to your laptop's and test to see if it is the calprit.
Nov 12, 2008 | Computers & Internet
Acer Aspire 5100-5022 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
