Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi gas string trimmer 30cc
Only used 12 times while trimming the engine slowed down and stopped. the cord will not pull out to try a re-start, as if it were jammed or frozen or bound up.  any idea's ???
  • Anonymous Jan 19, 2009
    sounds like the engine is seized up as happened to mine when someone put 4 stroke instead of 2 stroke oil in it!
    Needs a new cyliner and piston if thats the case
    Trying to find spare parts for mine but it will probably be cheaper to buy a new one!
SOURCE: Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
Posted on May 28, 2008
boscia
  • 163 Answers
SOURCE: Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Posted on Nov 29, 2008
  • 6 Answers
SOURCE: ryobi 30cc string trimmer 2230 4y30040b shaft overheating
mike try pulling off the motor and pour oil down the shaft.let me know how it goes
Posted on Mar 24, 2009
mrgauge
  • 17 Answers
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Posted on Oct 01, 2009
Testimonial: "Thank you! Just what I needed."
SOURCE: ryobi 30cc trimmer setting the timing belt
I set the crank pulley with the slot in the mag (shiny) section pointing up toward the camshaft (appeared to be top-dead-center looking thru SP hole). Set the deep hole in the cam pulley down to align with the crank slot. Slipped on the belt and surprise-surprise it fired right off. May need a bump one tooth either way, but too late to run it much tonight.
Posted on Jul 18, 2010
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
The Ryobi28020 weed eater seems to be flooded
Do not choke,Hold trigger down and pull the starter several time to clear the carb. of gas . You may have to remove the spark plug and dry it.
Aug 16, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have just bought a Ryobi Expand-it 30cc multi tool 4 stroke. Using it for the first time I filled the oil as instructed, put the petrol in as instructed and then started the machine after 2-3 minutes I...
This may sound like a dumb question, but did you mix the fuel and put it in the machine? If so, you shouldn't have. 4 strokes don't take mixed fuel. You must put the SAE 30 Oil (Not 2 cycle Oil) in a different chamber. Let me know, PLEASE!
Jim
Aug 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Hi i wonder if you can help my Ryobi hedge trimmer has a problem with the pull cord it works goes in and out but it does not turn the engine over is there maybe a key way or something that maybe broken...
Hello Nick,
Inside the cord attaches to a plastic wheel which cranks the engine. This cord can become loose or can break after some use. Try opening the plastic casing where the cord is to see if this is the problem.
Thanks
Jul 25, 2011 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
I don't remember how to start my weed eater;i've lost my manual
Pump the gas bubble near the black box air filter. Start pulling the string. Keep pulling until it turns.
Thanks
Jun 03, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
Nov 29, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Ryobi 30cc string trimmer 2230 4y30040b shaft overheating
Mar 22, 2009 | Ryobi Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
218 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
