CANON NP1215 PLENTY OF A4 PAPER AND TONER BUT IT WON'T STOP FLASHING FROM E TO 000
    Problem Solver:
  • 19 Answers
Check fuser lamp
Posted on Jan 03, 2009
My canon ir 3320i copier toner is leaking from drum unit fix it
Can u plz Check Cleaning Blade and Mylar sheet for cut,
Check Charge Roller if gone bad.
if both seems to be ok, then change Drum Unit .
Aug 13, 2017 | Canon Office Equipment & Supplies
Show me a picture of the waster toner on canon ir3035
It's in the front of the machine,abowe the paper casette.Part number for the waste toner box is FM2- 0303-000
Oct 08, 2014 | Canon iR3035 Copier
DEAR SIR I HAVE PURCHASED IR 3300 RC MACHINE . I HAVE 2 PROBLEMS. 1. IT ALWAYS DISPLAYS REPLACE THE WASTE TONER . BUT THE WATER TONER CONTAINER IS EMPTY. THE REP SAYS THER IS A PROBLEM IN SENSOR ....
regarding your first problem:
The waste toner container box neck must be always clean, because on the neck are two round dents, where optical sensor reads status. The permanent solution is to disconnect the sensor, his wires are above waste box ( white connector ).After disconnecting the sensor be sure to empty box every 60 000 to 100 000 copies.
Now the second problem:
Do you mean that paper cant be picked up? Does other paper sizes comes trough?
For start clean the pick up roller wich is locate inside the right door ( on top of the door ) in some cases covered with plastic cover.
Note: when you putt the paper in bypass, be sure to select correct paper size, paper type and from where to pull paper( bypass ).
If you want service manual write on emma.servis@gmail.com
Hope that helps!
Aug 30, 2010 | Canon imageRUNNER 2200
Have a canon c130.changed toner and still getting dark streaks on copies. Have cleaned all I could find inside still dark streaks
Try doing a "stop test." You would induce a jam before the paper reaches the fuser.
Just open a cover while printing and hopefully some image has been transferred to the paper. If the defect exists already then the laser unit, or document scanner may be causing it.
If that eliminates the dark streak, then obviously the fuser FG6-3720-000 should be changed.
Whit
Item, Inc
Aug 18, 2010 | Canon C130F Black and White Copier
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
My old Canon NP1215 Copier: -First copy is
most probably a change of the drum and cleaning blade is needed ,check also the fixing/fuser roller
Jul 11, 2009 | Canon Office Equipment & Supplies
'paper send error'
Did you buy this printer new & how old is it, I think you should contact the people you got it from
Jun 15, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
How many copies should a copier produce before changing a drum
I bought a km1620 copier. but copied only A4 size paper. No longer paper can not print except A4 paper. how can I change copying system. And how can I count copy. pls. mail me.
mizan
Jun 12, 2009 | Kyocera Copystar CS-1620 Black and White...
CANNON NP1215 COPY MACHINE
Coiincidence ??? E000 is a fuser error
Sep 25, 2008 | Canon imageRUNNER 1023iF Black and White...
89 people viewed this question
jasbo
jasbo
