Question about Sharp AR-507 Copier
Jams but only w/sheet feeder
Hi, I have a Sharp AR-507 copier that no one can fix or even diagnose. Two different copier repair guys have worked on it and by now pretty much everything that has to do with paper movement has been replaced. The copier works great when you put a single sheet on the glass, doesn't matter if making 1 or 50 copies. HOWEVER if you put one sheet in the sheet feeder, (much less 2 or 3 or 4) the machine immediately jams up. We took off the document sorter because one person thought the problem was in there somewhere, but still has the same problem. Works great for copying off the glass but always jams the paper (supply paper) when the tray feed is used. Thoughts? Thanks. Dave
  • Dave Shipper Aug 14, 2008
    The automatic document feeder is what will not even do one copy, just immediately causes a jam.
  • Tim Babcock
    Tim Babcock May 11, 2010
    When you mean the sheet feed you are talking the bypass tray or the automatic document feeder?
  • Sharp Master
  • 2,794 Answers
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Posted on Aug 14, 2008
Sharp AR-507 "Close the document feeder" error even it is already close...any suggestions and solutions please...
The document feeder has some kind of plastic nose that goes in to the sensor hole. Locate it and check for damadges.
Jul 05, 2010 | Sharp AR-507 Copier
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
Error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
Dec 02, 2009 | Sharp AR-507 Copier
Ar 507 F2-37 How to fix?
ID pattern reading error.  This time its in the optics section.  It should be looked at by a technician because there are timing adjustments that need to be done.  If they are not done correctly you will get very poor copy results.
Oct 22, 2008 | Sharp AR-507 Copier
L6-10 error on startup with Sharp AR-507. Any help?
L6-10 LSU error??»??»??»??»??»
Repair for!
Sep 03, 2008 | Sharp AR-507 Copier
Problem with Sharp AR-507
the Paper does not Jam. The copier just indicates that it is processing data but never seems to print. Seems to print every now and again if we change the fonts to download fonts. Not sure if there is an easy fix
Jun 11, 2008 | Sharp AR-507 Copier
Ckeck the glass on the left side it is about 1inck by 12 inch for white out on it also clean the optics.On your curling problem install fresh paper you can check your fuser temp. in sim 43-1 change it to 180.
Nov 07, 2007 | Sharp AR-507 Copier
Sharp AR-507 Copier Logo
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
