I tried to image copy disk (with windows XP Home SP3) to another disk in my system using Norton Ghost 10. I lost windows and I am unable to boot up my computer. Is there a way for my to recover windows and be able to boot up if I don't have a Windows XP disk. I only have the Recovery Disk from the computer OEM and if I try to boot up using that disk it doesn't work. Of course, I adjusted the BIOS when using the Recovery Disk. Also, I don't have an emergency boot-up disk. I will appreciate your help.
  • 1 more comment
  • flat2feet Aug 14, 2008
    Please, if you refer me to a web site where my "solution" is given, check to make sure the web site has the information you want me to see.
    When the system is turned on and starts the boot-up process, the words "Missing Operating System" appear on my screen and then the boot-up stops at that point. The only thing that works is F2. I can get the BIOS settings and adjust them BUT I do not have the choice of selecting "the last known good configuration." I am unable to use F8 or F5.
    As I wrote in my original post, I was trying to obtain an image copy of Drive C: and put in onto another disk, Drive D:.
    I believe my computer was put into DOS to run the Norton Ghost 10 and that's where it is now. It never gets into Windows and, therefore, I cannot run Ghost again, or any other program until I can restore windows.
    Genius:
  • 2,028 Answers
If you can't use the F8 feature, then I'm afraid you will have to acquire an operating system disc. During a couple of ghosting attempts, I've had the OS completely erased, not real sure why, or what I did.
Posted on Aug 14, 2008
  • 1,183 Answers
Disable your hardrive in the BIOS and then check, if you are able to to boot from the OEM cd.If successful,turn off the computer re-enable the hardrive in the BIOS and try the Boot again. Without the operating system cd you would not be able to recover the windows. If the boot is not successful you need to source another OEM windows cd from the manufacturer.
As you have upgraded to windows service pack 3 and if the OEM cd is windows service pack 1 or lower it may not boot at all.
Thanks
Proton
    Master:
  • 397 Answers
Where was the destination for your ghost image? was it to another partition or folder on your harddrive, a seperate harddrive or DVD disks?
  • Richard Finch Aug 14, 2008
    In this situation now, I would slave your harddrive to another machine, (there are a few ways to do this, if you need help just ask), now I would use file recovery software to recover all your personal important files, this one is free.
    http://www.pcinspector.de/Sites/file_rec...
    Your files will still be there, the chances are the MBR is damaged and that is why you are getting the no OS detected error.
    If I read your first post correctly you only have a recovery CD, the chances are this recovery CD has the abilty to access the recovery partition on your harddrive and does not contain a full version of windows.
    If you have a COA sticker on the side/bottom of your machine you can use an OEM copy of XP home or XP pro to reinstall your OS. If you don't have a COA sticker you can get your CD install key from your copy of windows on your harddrive. Magicaljellybean (silly name I know) is a small application that you can use to recover the CD key from windows, ALSO you can use it to recover the CD key from a dead OS:
    http://www.magicaljellybean.com/keyfinde...
    A lot of my work is file recovery, if you need any more help just let me know.
  • 6,487 Answers
You can try to go to your BOOT menu when you restart the computer then press F5 or F2 then go to advance you will see there the Boot menu and try selecting Last Known Good Configuration if that one did not work try Booting in safe mode...
Hope that helps.........
  • Mark Gil
    Mark Gil Aug 14, 2008
    If you cannot even go to the Boot menu and with the error message that you have , the next step here is to install a new operating system using a XP installation CD...
    Master:
  • 521 Answers
Rather then confusing you by giving you some short confusing answers just to try is not fair so i will give you the link to the complete procedure of recovring it .
given on the site below
http://www.edmartechguide.com/
Posted on Aug 13, 2008
  • tech expert12 Aug 14, 2008
    the information is present there but unable to copy so please check.it will help you.thanks
  • 13,434 Answers
If you use the norton ghost to copy the image back?
does it even try to start up?
try turning the automatic restart on system failure off
tap f8 during startup so the advanced start menu comes up and select disable automatic restart on system failure.
  • Ekse Aug 13, 2008
    this is the screen that should come up when you keep tapping on f8
SOURCE:
How to use norton ghost
GHOST is a program to copy one ENTIRE disk-drive to another disk-drive. Check www.norton.com for details on how to use the software.
Feb 26, 2014 | Microsoft Windows 7 Home Premium 64BIT...
IM USING GHOST TO TAKE IMAGE FROM ONE HARD DISK TO ANOTHER.IS IT POSSIBLE TO TAKE IMAGE FROM ONE HARD DISK TO TWO ANOTHER HARD DISK AT A TIME.IS IT ANY S/W TO DO THAT.ARE ANY SOME OTHER WAY
If the hard disks are identical and they are connected to identical computers, you can use UDP cast. This can be downloaded from the Internet, free of charge.
The computers should be on a network for this.
Copy UDP Cast to CD and boot all the computers with the CD. Select the source computer as the 'Sender' and other computers as 'Receivers'.
Start to send from the source computer. Probably In an hour, all computers will have a 'ghost copy' of the source computer.
Using this method you can 'ghost' even 20 computers!
Nov 12, 2010 | Symantec Norton Ghost 14.0: Windows
Ghost disc will not boot, not recognized as valid windows copy
If it's a Norton disk, call Norton, it should be bootable. If it's a disk you burned, it may not be a bootable system disk. Make sure your computer is set to boot from CD/DVD drive in the bios (setup) Press F2(usually, sometimes it's delete) while booting, go into setup, and make sure under boot devices/sequence that your disk drive is first in the boot sequence. Try the disk on another machine to see if it's the disk, or the machine. If it's the disk, Call Norton (if it's theirs) or have someone make another one for you.
Jun 12, 2010 | Symantec Norton Ghost 14.0: Windows
Hard drive is full
Aquire disk imaging program such as norton ghost. Install 2nd, larger HDD into existing computer. Boot computer using ghost boot disk. "Image" existing HDD to newer, larger HDD.
Remove existing HDD. Set 'new' HDD to proper position (Master, etc).
Boot computer.
Joy.
Feb 19, 2009 | Microsoft Windows XP Professional
Dell poweredge 1650 and norton ghost
okay, hate to answer my own question. Where I got confused was with the protocol.ini file that is used in Norton Ghost on a boot disk to load the network information, including the network protocol to be used (netbeui in this case) and what network card was to be used. Thus the last part of the protocol.ini file is where I needed to add the missing information. I needed to add the slot = required value to identify what one of two network cards in the dell PowerEdge 1650 was to be used to connect to the ghost server (in this case, the two cards were idenified by a number such as 0x0110 and 0x0120). The strange thing is that I also noticed that there is a third network port on the back of the server, but I am not sure if it is active or not, but nothing came of as of yet. But I am now happy to report that I can connect to the ghost server to image the machine I need to image.
Edward
Nov 19, 2008 | Computers & Internet
How to format c:drive as it contain vista operating system . i only have a vista recovery disc which only install back vista to its factory level. please suggest me the procedure to format c:drive so...
hi,
yea you may, but make sure that you have already created a *Ghost* image of your current setup.
All you need is a bootable CD with some utilities which will help you out.
Try "hiren's Magic Disk 9.5" : it is bootable disk with proper menus and lots of utilities to make you king of your system.
This disk is usually used by System professionals (including me) :)
Instructions:
1. Boot your system with this magic disk
2. Goto Clone Disk option (Ghost disk)
3. Choose Best compression version
4. utility will start Symantec Ghost which will ask you for the source partition and destination partition for making images.
5. proceed with proper answers.
6. once the ghost imaging is complete, store this ghost image in your external storage drive
7. again boot your system with this magic disk
8. goto Partition utilties
9. Select Acronis Partition manager
10. You'll love to use this software for hard disk maintanence.
Regards,
kuldeep
Nov 14, 2008 | Computers & Internet
I need a recovery disk for my Vista OS preinstalled on Acer Aspire T180. Can I create it by myself? (Recently my system crashed and I had to a tecnichian for using his recovery disk)
You can use a hard drive imaging program such as Norton Ghost to create a recovery DVD(s). Norton Ghost is available as part of System Works or as a stand alone program. Power Quest's Drive Image is also an alternative, however it is too old to be compatible with Vista - you could do a Drive Image outside of Windows - booting off the Floppy.
Sep 09, 2008 | Acer Computers & Internet
Ibm thinkpad T40 Hard Drive change out
After fdisk and format you need to ensure that operative system is installed into yor hard drive. Using ghost you restore the image disk by booting from ghost image CD if you made a bootable image disk. Ensure Bios is set up to boot from CD.
If you used Norton Ghost ensure you captured the image of full bootable original hard disk drive for same computer. If it does not boot after restoring ghosted image, than the image it is probably not complete. If hard disk image is not good, easiest thing to do is using Windows install CD to installl again operative system, then you eventually restore ghost image.
Aug 17, 2008 | IBM ThinkPad T40 2373 Notebook
Transferring info from one hard drive to another
No that wont work.  :)
You will never be able to copy all the files from windows.
Here is my suggestion.
Their are several programs out their to help you accomplish a disk to disk copy. I personally use Norton Ghost. Action True image is another.
This particular program i have found extremely reliable.is Norton Ghost 2003. This is a hard drive cloning software that runs from dos.
When you are running windows, you cant copy by drag and drop, all the files. Windows just wont let you move the important files.
You could purchase norton ghost 2007. That software is designed to work from windows. You can install it and then clone the running drive onto the new fresh drive.
After you clone the drive, you can just set it to "active" and switch the boot order in the bios. Or just unplug the old drive.
I can assist you in getting a copy of norton ghost dos edition, and clone the drive. However it would require direct connection to your pc, and phone support to walk you threw it once your into dos.
Oct 11, 2007 | Computers & Internet
O.S.
you can use windows backup facility, start>all programmes>accesories>system tools>backup, or use a third party software similair to norton ghost if you wish to back up the operating system as well.
Sep 03, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
129 people viewed this question
Ekse
Alun Cox
